Posted: β2020-07-03 01:28 PM . Last Modified: β2024-04-08 01:37 AM
(CID:113641559)
Dear smatsa,
FYI..The following is the latest DDF version available in DCE 7.4.1 for MGE UPS.
If you are looking for a specific Model DDF, you may check here.
Bala
(CID:113641574)
Dear smatsa,
Bala
(CID:113641574)
Can I update only DDF file, or must update sever? The current version of the server is 7.2.0
Nemanja
(CID:113641651)
You can update the specific DDF file by getting the latest DDF file from the DDF team from EcoStruxure IT Help Center page.
However, I would suggest you to update the DCE version to the latest version 7.4.1 as there are many fixes done in the latest version. By upgrading to the latest DCE version, the DDF files also would be updated. For this reason, Its highly recommended to upgrade to the latest version. To receive the latest upgrade links, DCE needs to be under Software support contract. If its is, please contact your local country technical support.
(CID:113641649)
Ok, thank you
(CID:113641647)
You are welcome! Have a nice day!
(CID:113641645)
Can you tell me how can I get updates for DDF files? Must I fill the request form for new DDF or send email to someone.
(CID:113642976)
Posted: β2020-07-03 01:28 PM . Last Modified: β2024-04-08 01:36 AM
DDF files can be received by filling the form here. There is no need to send an email, and all DDF requests are fulfilled from EcoStruxure IT Help Center-device support.
(CID:113642984)
Posted: β2020-07-03 01:29 PM . Last Modified: β2024-04-08 01:36 AM
Must I do an SNMP walk for update?
(CID:113643002)
Yes, please do the SNMP walk and attach it. It would be great. If you are referring to MGE UPS, then it may not be required, but its better to attach the SNMP walk.
(CID:113643005)
Ok, I will do that tomorrow.
(CID:113643007)
Posted: β2020-07-03 01:29 PM . Last Modified: β2023-10-20 05:07 AM
