Posted: β2020-07-02 12:40 PM . Last Modified: β2024-04-09 11:45 PM
can I add the Netbotz camera view on portal. and how to add pictures from PC to portal.
Ali
(CID:96764415)
Yes , Ali you can view Netbotz camera on portal. Simply Add to Device and attach that pictures.
Muhammad Shahzad
(CID:96764428)
Hi Shahzad, can you please navigate the path step by step.
(CID:96764436)
Hi Ali, This has been discussed earlier in this thread: http://dcimsupport.apc.com/questions/96043546/
(CID:96764615)
Thanks Soren
(CID:96764627)
Posted: β2020-07-02 12:40 PM . Last Modified: β2023-10-31 10:18 PM
