How to reserve U-Space in DCO 7.4.5
  • EcoStruxure IT forum
  • How to reserve U-Space in DCO 7.4.5
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 12:39 PM . Last Modified: ‎2024-04-09 11:46 PM
976
    kindly help me how to enable reserve U-Space option  in DCO 7.4.5.
Regards
Ali
(CID:96764413)
  • Data Center Operation
Replies 7
976
Hi Ali,
Currently there is no option to reserve a U-space, but as a work around you might want to use a none-powered device (ex. a patch panel) and name it "reserved u space".
(CID:96764421)
Hi Jef,
          if I follow your instruction is it possible to see the reserved U-space in reports. see the attached picture.
(CID:96764444)
Hi Ali, The reserved U space in reports are most likely work order related, The above mentioned work around is simply to occupy (sort of reserve) the space for your future use. I've just noticed that a similar request/question has been treated previously, please visit the following page, it contains very useful info: http://dcimsupport.apc.com/questions/93913660/reserved-uspace-in-a-rack-without-creating-a-work-orde...
(CID:96764447)
976
Hi Ali
The reserved u-space is a feature in the StruxureWare Data Center Operation: Change
The reserved u-space is described in more detail Equipment stages on StruxureWare Data Center Operation: Mobile
The KPIs are described in more detail including which licenses are needed for the KPI to function Capacity History (KPI) Description
(CID:96764621)
Thanks Soren. means without work order it is not possible. but how to see reserved U space in report. see the following picture
(CID:96764668)
Posted: ‎2020-07-02 12:40 PM . Last Modified: ‎2024-04-09 11:45 PM
Hi Ali, You are right. With out the work order functionality in the change module it is not available. The report you showed in the first picture is based on KPIs. These are recorded once per day and therefore you might need to wait 24 hours before any reserved space data showing in the report. You might use following to manually force the KPIs to be recorded: http://dcimsupport.apc.com/display/UAOp74/Capacity+History+%28KPIs%29+over+Time
(CID:96764672)
Posted: ‎2020-07-02 12:40 PM . Last Modified: ‎2023-10-31 11:07 PM
