CAD Import drawing scale in DCIM Operations 7.4
Showing results forย
Did you mean:ย
  • EcoStruxure IT forum
  • CAD Import drawing scale in DCIM Operations 7.4
124
110
65
Back to EcoStruxure IT forum
Posted: โ€Ž2020-07-02 12:25 PM . Last Modified: โ€Ž2024-04-09 11:51 PM
1197
I tried to import a CAD floor layout into DCO 7.4 and it is importing successful but with wrong scale and wrong dimensions. The dimensions on the rooms created using room detector is coming wrong. Is there a Standard Scale that we need to setup in the CAD drawing before we import, so that the dimensions and zoom to get complete floor layout in the preview is achieved.
(CID:96044918)
  • Data Center Operation
1195
Hi shemilusman the units of measure is specified in the DWG file it self. It is changed using AutoCAD - here is a good tutorial that explains how to change the units of measure in autocad: https://youtu.be/t7Kr0P0GYHE
(CID:96763931)
Replies 7
1195
Could you please add some screen captures to illustrate the issue and your expected "correct" dimensions/scale.
DWG drawing must have measurement units (eg. mm or inches) specified to allow import drawing at correct scale:  CAD Import Supported Entities
(CID:96044932)
Hi Jef, Can you please advise where do we specify measurements for the DWG drawing. Thanks & Regards Shemil
(CID:96044933)
1196
(CID:96763931)
Hi Anders Jensen, The video helped and it worked. Thank you for the information. Regards Shemil
(CID:96763933)
1194
Can you import Visio drawings ?
(CID:96764014)
Hi Brian, I took the liberty of asking this as a separate question and tagging you, as you most likely will not get an answer in here ๐Ÿ™‚ Hope it helps! /Kristoffer
(CID:96764765)
Posted: โ€Ž2020-07-02 12:26 PM . Last Modified: โ€Ž2023-10-31 10:17 PM
Terms & Conditions Privacy Notice Change your Cookie Settings ยฉ 2025 Schneider Electric
