Multiuser access to Genome Library
  • Multiuser access to Genome Library
129
72
Posted: ‎2020-07-02 12:24 PM . Last Modified: ‎2024-04-09 11:52 PM
806
Hi guys,
Does Custom Genome library support multi user write actions?
Subject to an obvious rule of not making changes to the same genome entry, can two users add and edit genomes and save their work without a multi user clash error?
(CID:96044837)
  • Data Center Operation
806
Hi Lukasz,
We do support multi user write actions to the custom Genome Library.
If multiple edits to the same genome device from different clients have been done the user trying to modify already modified data will be notified that has changes will not be saved.
Some more information regarding working in a multiuser scenario can be found here:
http://dcimsupport.apc.com/display/UAOp74/Understanding+what+Happens+when+Multiple+Users+Work+Simult...
(CID:96044920)
Replies 4
Hi Lukasz Staciwo , we will look into it. @community - share your knowledge/ideas with Lukasz if any!
(CID:96044914)
807
Hi Lukasz,
(CID:96044920)
Thank you Soren, much appreciated.
(CID:96044954)
Posted: ‎2020-07-02 12:25 PM . Last Modified: ‎2023-10-31 11:22 PM
