Blocked access to the server DCE
  • EcoStruxure IT forum
  • Blocked access to the server DCE
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 12:36 PM . Last Modified: ‎2024-04-09 11:47 PM
614
StruxureWare Data Center Expert in 7.2.6 do change the time zone - server locale and thereafter the blocking access to the server, any idea of what you can do to regain access?
(CID:96764355)
Replies 4
Hi Oscar! What do you mean about blocking access? Are you trying to connect via client application or via web-browser? Is there some error messages?
(CID:96764368)
Hi Valentin, Access attempt by the two options but you can not, make a ping to the ip and responds
(CID:96764516)
Hi Oscar,
Are you still experiencing problems after setting the server locale?
A reboot of the server is done if the time settings or locale are changed. This might be the reason you cannot access the system.
More information can be found here: Time Settings
If you still experience issues we would need to investigate the log files. Those can be found using a web browser and access http:///nbc/Logs
(CID:96764630)
Posted: ‎2020-07-02 12:36 PM . Last Modified: ‎2023-10-31 10:17 PM
