Backups DCO
  • EcoStruxure IT forum
  • Backups DCO
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-04 04:41 PM . Last Modified: ‎2024-04-05 12:09 AM
870
Backups DCO
Hi All
How I can check the backups in the DCO (Web-DCO) ?
thanks a lot
Jean-Pierre
(CID:130097573)
  • Data Center Operation
Posted: ‎2020-07-04 04:42 PM . Last Modified: ‎2024-04-05 12:09 AM
870
For DCO 8.X, go to Webmin, (https://dco_ip_address:10000)
Go to StruxureWare DC Operation, then Backup.
Backup files, by default, are saved in /data/backup
(CID:130097576)
Replies 4
871
(CID:130097576)
Hello Christopherus
Thanks for your answer, but the security Settings from any browser in Windows 10 (IE 11, Edge, Firefox, Chrome, etc....) don't allow this Connection.
Only with older browser on Win 7 accept this.
Schneider Electric should give another way to check the backups in the DCO.
Kind Regards
Jean-Pierre
(CID:130099175)
Those browser should be fine with DCO web client as well as webmin.
Are you getting warning on self signed SSL certificate when accessing webmin?
You can replace that with one purchased from trusted certificate authority.
Details on steps:
Changing SSL certificate on the server
(CID:130099177)
Posted: ‎2020-07-04 04:42 PM . Last Modified: ‎2023-10-20 05:02 AM
