Back connections on patch panels - available where?
  • EcoStruxure IT forum
  • Back connections on patch panels - available where?
125
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 04:46 PM . Last Modified: ‎2024-04-08 12:26 AM
818
A customer is asking: Is there a way to get the back connection information on a patch panel shown somewhere, besides on the properties dialog?
In the example below, they are interested in the four connections that has a description. Are they available somewhere in the staging (ETL) database? REST API? Please notice, that two of the connections are not "real" yet, they only have a description and are not connected yet.
Thanks in advance,
(CID:120130847)
  • Data Center Operation
Replies 9
818
Hi Christian,
For the ETL export (ETL Export Database) the information might be in several tables (such as configuration_item_relation, relation_property and relation_endpoint_property). However, as illustrated the "Network Management" might be used to display the network connection details and we can also use the "Export Table Data" feature to save the data to a file:
(in this illustration, the connections are back-to-back between two patch panels)
hope this helps,
Kind regards
(CID:120130919)
Posted: ‎2020-07-03 04:47 PM . Last Modified: ‎2024-04-08 12:26 AM
That only works for connected ports. I am looking for a way to list ports that have a description, but not a connection yet.
(CID:120135285)
Hi Christian,
I was wondering if the Equipment Browser and it's "Port Description" field could be used, please see the following illustration:
Kind regards
(CID:120135781)
Jef Faridi Is the Port Description field exported to the ETL database?
(CID:123996505)
Hi James,
I will check and get back to you asap, thanks.
Kind regards
(CID:123996522)
Hi James,
The Port Description filed is not included in the ETL export database.
Kind regards
(CID:123996602)
Thanks Jef Faridi.  Is it held in any internal DCO DB?  What I would like to do is create a report that shows all ports with a description next to it in a room.
(CID:123996699)
Hi James,
It is in DCO DB, but not in export database. I was wondering perhaps you might want to contact/discuss this with Lasse Simonsen, who is in direct contact with our CSP team (offering customized solutions), thanks.
Kind regards
(CID:123997088)
Posted: ‎2020-07-03 04:47 PM . Last Modified: ‎2023-10-20 05:02 AM
