BacNET integration
  • BacNET integration
127
65
Posted: ‎2020-07-05 11:13 PM . Last Modified: ‎2024-04-03 12:12 AM
1783
BacNET integration
Hi, is possible integrate BacNET devices with DCE ussing protocol converters or some kind of Gateway, any Device recomendación,
Regards
(CID:151062138)
Hello Sergio, the answer is Yes, ok, el How for me is not easy for explain now because I don´t handle the AS configuration, but you can use an Automation Server (From Schneider) for receive in Bacnet and convert to Modbus TCP using it´s configuration, is not hard I saw the AS GUI but try to contact some EBO tech/Eng for get help...
Erlinson Bravo Garcia
(CID:151062175)
Replies 5
(CID:151062175)
1783
Hi Sergio,
I have integrated bacnet into DCE using a SIP gateway that converts bacnet to modbus tcp as long as you get the slave address and the registers a ddf can be written for your device but ddf's for modbus are quite simple to write or ammend.
cheers
mike
(CID:151062178)
hi, friends,
 thanks for yours answers,
I think we will try Schneider Automation Server.
Regards
(CID:151062887)
Hi Sergio,
You can check my tutorials at the following links:
and many more such customization posts I have submitted.
Regards
Vineet
(CID:151062233)
Posted: ‎2020-07-05 11:13 PM . Last Modified: ‎2023-10-20 05:02 AM
