84654members
354004posts
BacNET integration
DCIM_Support
Picard
Picard
530
BacNET integration
This question was originally posted on DCIM Support by Sergio on 2019-11-01
Hi, is possible integrate BacNET devices with DCE ussing protocol converters or some kind of Gateway, any Device recomendación,
(CID:151062138)
DCIM_Support
Picard
Picard
Re: BacNET integration
This answer was originally posted on DCIM Support by Erlinson Bravo Garcia on 2019-11-02
Hello Sergio, the answer is Yes, ok, el How for me is not easy for explain now because I don´t handle the AS configuration, but you can use an Automation Server (From Schneider) for receive in Bacnet and convert to Modbus TCP using it´s configuration, is not hard I saw the AS GUI but try to contact some EBO tech/Eng for get help...
(CID:151062175)
5 Replies 5
DCIM_Support
Picard
Picard
(CID:151062175)
DCIM_Support
Picard
Picard
531
This answer was originally posted on DCIM Support by mike sutton on 2019-11-02
Hi Sergio,
I have integrated bacnet into DCE using a SIP gateway that converts bacnet to modbus tcp as long as you get the slave address and the registers a ddf can be written for your device but ddf's for modbus are quite simple to write or ammend.
cheers
mike
(CID:151062178)
DCIM_Support
Picard
Picard
This comment was originally posted on DCIM Support by Sergio on 2019-11-05
hi, friends,
 thanks for yours answers,
I think we will try Schneider Automation Server.
(CID:151062887)
DCIM_Support
Picard
Picard
This answer was originally posted on DCIM Support by Vineet K. Sarin on 2019-11-03
Hi Sergio,
You can check my tutorials at the following links:
and many more such customization posts I have submitted.
Vineet
(CID:151062233)
DCIM_Support
Picard
Picard
🔒 Closed
