Posted: 2020-07-02 10:00 AM . Last Modified: 2024-04-10 01:02 AM
Hi, i have multiple AHU's and have the option of integrating / controlling them with SE Enterprise server. I want to know which protocol between BACnet IP & BACnet MSTP should be used and why, also in terms of integration/ control with Enterprise server/ Automation server what functionalities will be compromised. The confusion is whether ip based protocol will integrate in same manner as RS485 based?
(CID:93913667)
Hi Shaf,
I do not have the answer to your question but would suggest posting it to the Building's community
https://buildingscommunity.schneider-electric.com
(CID:93913701)
In terms of performance, I would suggest BACnet over IP. See ( Architectural Guidelines 1.5.pdf , Architectural Guidelines 1.6.pdf). As far as integration goes that depends on what kind of integration and what platforms you intend to use. Can you elaborate?
-RayLugo
(CID:93913833)
Posted: 2020-07-02 10:00 AM . Last Modified: 2023-10-31 10:17 PM
