Auto-generate monthly report
Showing results forย
Did you mean:ย
  • EcoStruxure IT forum
  • Auto-generate monthly report
124
65
Back to EcoStruxure IT forum
Posted: โ€Ž2020-07-04 10:10 PM . Last Modified: โ€Ž2024-04-04 03:25 AM
1217
How can i auto-generate monthly report in both graphical and table form.(i have attached a sample if the graph to be generated). We generate over 110 of these reports monthlyand it is time consuming(sometimes 3days) and tedious. We want to schedule this task on the Struxturware DCE to be generated automatically on a said date and time to save time and improve accuracy.
(CID:133375174)
1218
Dear ADEKUNLE AGBOKE,
From your question:
How can i auto-generate monthly report in both graphical and table form...
In current DCE-7.x it is impossible: on Feature requests already repeatedly gave such requests, and I including ๐Ÿ˜€. See for example Steven Marchetti answer on topic :
Although the exported file is a .txt, it is actually a comma delimited file or in essence, a .CSV format. As for the option of exporting a graph using (I'm assuming) an e-mail export, I have added this post to an enhancement request that already exists for this feature. I have no timeframe nor can I state that this feature will make it into the product but your post is now part of the enhancement request.
With best regards.
(CID:133375331)
Replies 6
1219
From your question:
With best regards.
(CID:133375331)
Posted: โ€Ž2020-07-04 10:11 PM . Last Modified: โ€Ž2024-04-04 03:25 AM
I've added this to the existing feature request.
Steve
(CID:133375337)
Thanks Steven, I really hope this can be sorted out soon.
My team and I are not meeting up with with delivering energy utilization report every month
(CID:133375612)
You're welcome but at this time, I can not say when or even if this feature will actually make it into the product.
(CID:133375665)
Alternative way:
Periodically pull those historical data from DCE to a reporting app, for it to churn out required monthly reporting in specific format/calculation. Ideally the reporting application has its own database to store those data.
DCE has web service api for developer to pull those data out:
StruxureWare Data Center Expert Web Services API
To pull historical data,
Identify the device and sensor
Device Service Methods
Then pull data using applicable services
Sensor Service Methods
Chris
(CID:133375403)
Posted: โ€Ž2020-07-04 10:11 PM . Last Modified: โ€Ž2023-10-20 05:01 AM
Terms & Conditions Privacy Notice Change your Cookie Settings ยฉ 2025 Schneider Electric
