Posted: 2020-07-03 03:25 AM . Last Modified: 2024-04-08 11:58 PM
Hi There is no power (input and output) so it's difficult to work with it. Normaly it's 2 Power Input and 8 output (look at the picture)
Best regards
Rocchino
( also https://dcimsupport.apc.com/devices/view/Ap7721/APC )
(CID:106206074)
Hi Rocchino,
AP7721 is a rack mount transfer switch (ATS). Currently modeling a rack ATS as a power device is unsupported in DCO.
We have an existing/registered feature request in our system, and I will go ahead and add you to that case (and will email you the case no.)
For the time being you might want to check out the following shared Tip:
Kind regards
(CID:106206084)
Posted: 2020-07-03 03:26 AM . Last Modified: 2023-10-31 10:15 PM
