Anyone have a working example of calling the REST API from Perl ?
  • Anyone have a working example of calling the REST API from Perl ?
129
72
Posted: ‎2020-07-04 11:39 PM . Last Modified: ‎2024-04-04 02:29 AM
3329
(CID:134032557)
  • Data Center Operation
  • Portal
3328
Hi Ed,
Happy to look at your CURL code - might help we see what's going on - or give me a base to work from.
Currently I have the simplest of Perl scripts trying to get a simple of assets (small steps).
I'm getting "500" error being returned.
500 Can't connect to dco.rhino-hosting.com:443 (Bad file descriptor) at simple.pl line 23.
This is against one of the the training servers.
use strict;
use warnings;
use LWP::UserAgent ();
my $ua = LWP::UserAgent->new;
$ua->timeout(10);
$ua->env_proxy;
$ua->credentials(
'dco.rhino-hosting.com:443',
'ISXO',
'user' => 'password'
$ua->default_header( Accept => 'application/json' );
my $response = $ua->get('https://dco.rhino-hosting.com/api/v8.1/assets');
if ($response->is_success) {
print $response->decoded_content; # or whatever
else {
die $response->status_line;
dave
(CID:134032607)
Replies 6
Hi David
I haven't used any of the REST PERL packages as I've tried to use only the installed software for SE for my scripting.  This is no doubt something that each client/programmer will have a view on.  Therefore I simply use a PERL system call and CURL.  I would not call this production or professional grade solution but it gets the job done.  If that helps, I'm happy to share a script
Cheers
Ed
(CID:134032589)
3329
Hi Ed,
use strict;
use warnings;
$ua->timeout(10);
$ua->env_proxy;
$ua->credentials(
'ISXO',
else {
dave
(CID:134032607)
Try HTTP rather than HTTPS - just as a test
(CID:134032614)
+1 on this comment.
Disable the auto routing from http to https via webmin if you are testing via http.
(CID:134032633)
That's done the trick - thanks!
And changed the authorisation to Basic.
Code now looks like this (in case anyone else is interested).
#!/usr/bin/perl
use strict;
use warnings;
use LWP::UserAgent;
use Data::Dumper;
use JSON;
my $address = "dco.rhino-hosting.com";
my $port = 80;
my $username = "user";
my $pass = "password";
my $url = "http://$address:$port/api/v8.1/assets";
print $url . "\n";
my $browser = LWP::UserAgent->new('Mozilla');
my $req = HTTP::Request->new(GET => $url);
$req->authorization_basic($username, $pass);
my $res = $browser->request($req);
print Dumper($res) . "\n";
my $response = from_json($res->decoded_content);
print Dumper($response) . "\n";
(CID:134032974)
Posted: ‎2020-07-04 11:39 PM . Last Modified: ‎2023-10-20 05:01 AM
