IT Optimize Module
  • IT Optimize Module
129
72
Posted: ‎2020-07-04 11:40 PM . Last Modified: ‎2024-04-04 02:28 AM
1132
IT Optimize Module
Does this module capable of doing asset management?
Like reading the server serial number and give other physical information about the servers?
(CID:134032714)
  • Data Center Operation
Replies 9
Hi there
We using the ITO module to provide Serial Number and OS of Servers amongst other things. At the moment we struggling to get power stats from Servers - currently investigation!
I hope this helps!
(CID:134032744)
When using the OS based protocols for discovery like WMI, SSH, and the VMware setting ITO should return server make, model, hostname, IP address, serial number and OS version. These are certainly useful for asset management. If guests are checked in the VMware discovery you should see similar info for guests in addition to their VMware host(s).
The out of band protocol, IPMI, should return power and server inlet temp info as monitored by the server's motherboard. The credentials used by IPMI are specific to the servers management card/port (usually an ILO, iDRAC, IMM or similar module).
In today's ITO I would recommend using IPMI to get power data.
Regards
Greg Sterling
(CID:134032762)
Thanks Greg, we have been using IPMI however the struggle comes with the credentials and our in-house security policies.
The issue has been escalated, awaiting feedback.
Kind regards
(CID:134033094)
1132
Can i get a PDF about this Module and what it suppose to do, Please?
(CID:134034073)
I have attached a high-level PDF which describes ITO and its purpose.
Regards
Greg SterlingITO_single.pdf
(CID:134034836)
Thank you very much.
How can i get something more detailed?
(CID:134035863)
Hey Eitan, please forward the attached doc to me as well.
Thanks and regards.
(CID:134035918)
Posted: ‎2020-07-04 11:41 PM . Last Modified: ‎2024-04-04 02:28 AM
Yes. Additional info can be found in the community here:
StruxureWare Data Center Operation: IT Optimize
the module also enables the following reports in DCO
Underutilized Servers Report
Server Power Consumption Report
Server Utilization Report
Regards
Greg Sterling
(CID:134036045)
Posted: ‎2020-07-04 11:41 PM . Last Modified: ‎2023-10-22 02:40 AM
