An internal error occurred during: "Loading model [com.apc.isx....
  • EcoStruxure IT forum
  • An internal error occurred during: "Loading model [com.apc.isx....
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 09:46 PM . Last Modified: ‎2024-04-07 11:36 PM
2138
Recently upgraded a DCE server appliance from 7.2.0 to 7.4.3.
Now when trying to log in the login screen hangs for probably 4 min or so at "Loading Surveillance model". When logged in a "Problem occurred" pop up appears as shown below.
If I dismiss the window and then click on the surveillance tab in DCE then the client hangs - I have to force the client to shutdown through task manager.
I have tried on 3 different laptops and have uninstalled and reinstalled DCE client 7.4.3 on one of them, but it made no difference.  I powered down and restarted the server, no difference.
Any ideas, or am I looking at a rebuild from scratch?
Regards
(CID:123348167)
  • bug
Replies 12
2138
When this started to happen to to our DCE (VM) the fix for us was to increase the memory allocation to it and haven't had an issue with it since.
(CID:123348172)
Thanks for the advice.
I did see your post on this, but unfortunately this is an appliance not a VM and I cannot increase the memory.
(CID:123348235)
Gotcha....Hopefully they will have some help for you shortly then!
(CID:123348238)
2138
Hi Garry,
Is this issue happening when you're launching the client or just when you try to click in to the surveillance view? If it's launching the client, uninstall and delete (or at least move) the .isxc folder from your C:\users folder. If you reinstall and we still can't get in, that doesn't bode well for the idea of fixing it without a restore.
You can try a restore but I'd suggest creating a backup first (if you can access the system). Test the system after restore (and before configuring anything other than IP) and I'd assume it will work. If you can then re-import a backup and the issue no longer happens, then it was likely something corrupt in the system itself. If re-importing the backup re-imports the issue, then it's something with the data.
You may want to share the logs on this. It may be some kind of communications issue with NetBotz appliances or potentially some thing to do with data from one of the NetBotz or it's cameras. http:///capturelogs  and delete whatever is there then create a new archive.
Steve
(CID:123348250)
Thanks.
When launching I get the error pop up window after a long delay on the splash screen that appears after entering my credentials.
I also have a config backup of both before and straight after the upgrade...
When the DCE client is uninstalled does that not delete the .isxc folder? I did uninstall and reinstall the client on one of the laptops I used...  I will try this though tomorrow when I get back to site.
One thing I just realised is that on the web page view of DCE, the camera images are displaying correctly.
I have the capture logs but did not want to post them on a public forum.
(CID:123348257)
Forgot to add, once logged in trying to view thecameras through the surveillance tab in the DCE client hangs the client
(CID:123348259)
Hi Garry,
No, the .isxc folder remains. There may be numerous folders there from previous versions and you can remove a specific version's folder as well. We don't delete it so the information doesn't get deleted when you install a new version and uninstall another.
Steve
(CID:123997011)
Oh good, so you can get in. Maybe purge some data if you can.
Also, if you can go to the device menu–>surveillance settings, perhaps changing some values like lowering resolution or frame rate or even disabling a camera (don't uncheck license camera, may delete associated images) may have some effect. If you can do that maybe you can troubleshoot to a specific camera causing the issue.
(CID:123348268)
Posted: ‎2020-07-03 09:47 PM . Last Modified: ‎2024-04-07 11:36 PM
OK I will try that anyway but it does seem odd that it happened on 3 separate laptops.
Having said that they had all been previously connected to this server with the V7.4.0 DCE client installed.  Maybe related.  Will find out and report back tomorrow...
I guess if this does not work then I am looking at a rebuild and hoping that the config backup does not contain data to make the problem reoccur?
(CID:123997013)
Hi Steve I can see the cameras in the web view (Chrome) but not in the DCE client.  As soon as I click on the Surveillance Tab the DCE client hangs solid.  I did try purging some surveillance data but can't purge it all.
Good to know about the .isxc folder too, never really though about how the client handles data and different versions...
(CID:123348276)
Hi Steve, unfortunately none of your advice worked so I had to rebuild the server.  The rebuild went smoothly and the servers is now working fine.   Unfortunately the full backup was way too large to backup and restore in the given timescales, so we have no historical data, but at least all is back up and running.
I think I have the capture logs for bother before an after the rebuild if you think that might help investigate the reason...
Regards
(CID:124520265)
Posted: ‎2020-07-03 09:47 PM . Last Modified: ‎2023-10-20 05:00 AM
