Posted: 2020-07-04 08:22 PM . Last Modified: 2024-04-04 04:13 AM
Hi all,
I want to add some portlets that will contain data from DCE in the from I need. What function should I use for this? I didn't get any helpful information from portal help page. Thank you
(CID:132666659)
Dear Dmitry Emelyanov,
Good help on your question can be found on a special web-page Configuring StruxureWare Portal.
In short, as follows from Jef Faridi response in topic , you need to check SxW portal connection to DCE server:
1. verify if the DCE user credentials are correct (DCE as a service provider). (ex: can be tested via DCE client software).
2. verify if your DCE is reachable from the Portal server. (ex. from the Portal workstation test the connection by using a web browser and/or DCE client software). I believe port 80 must be supported between the Portal and DCE server.
3. In the DCE portlet configuration/Preferences, verify if your DCE server is listed, you might need to re-select (the DCE server) and "Save".
I hope this is what you need.
With respect.
(CID:132666679)
With respect.
(CID:132666679)
Posted: 2020-07-04 08:23 PM . Last Modified: 2024-04-04 04:13 AM
Thank you for answer, I skipped the information about the portlets on this page.
(CID:132666695)
Hi spezialist
If I understand correctly, question is concerning developing own portlets - we do not have such guide.
Kind regards
(CID:132666699)
Hi Dmitry,
If I understand correctly you want to develop your own (customized) portlets, right? If yes, then unfortunately we do not have such guide.
Out of the box, the supported/available portlets (both for DCE and DCO) are listed here: Portlet data sources
Kind regards
(CID:132666693)
(CID:132666697)
Posted: 2020-07-04 08:23 PM . Last Modified: 2023-10-20 04:59 AM
