DCE7.5 + DCO8.2 Monitoring Error
  • DCE7.5 + DCO8.2 Monitoring Error
129
72
Posted: ‎2020-07-04 08:21 PM . Last Modified: ‎2024-04-04 04:13 AM
1177
Hello community.
My customer has two datacenters, in each one they have:
  1. DCE (7.4.3) Upgraded to 7.5
  2. DCO (8.0) Upgraded to 8.2
  3. Portal
  4. DCO - Disaster Recovery
Before upgrade DCE 7.4.3 monitored the DCO without errors, the database status reported by DCE was normal, but now, after the upgrade of both systems (DCE and DCO + DCO-DR) the reported status:
a. The StruxureWare Operations database status is unknown
b. The Struxureware Operations Server is unreachable
In first time I think maybe a customer´s network issue could be the cause, but after check the network health and some tests I tried installing a DCE demo in version 7.5 and DCO demo in version 8.2 in my laptop using vmware player and I get the same error messages....
Community, do you have any idea about the possible reasons? Could DCO 8.2.7 be a cure for this situation? for your time and support thank you very much.
Best Regards,
(CID:132666514)
  • Data Center Operation
  • bug
Replies 6
I had the same issue. It was solved with update of DCO to v 8.2.7
(CID:132666574)
Posted: ‎2020-07-04 08:22 PM . Last Modified: ‎2024-04-04 04:13 AM
Dear Erlinson Bravo Garcia,
Boris Majdandzic is right, this is a very known bug that, according to Jef Faridi answer in topic :
Update:
DCO 8.2.7 is released now, contains the fix.
With respect.
(CID:132666605)
Hello Community,
I think it´s on the dco side, I ran the isx_devicewalk and I get OID answers, when I compare with the schneiderops.xml file I can see that dce show the readed status of the respective OID example:
In dce one error alarm is: Unknown status for ETL (in red color, severity:Error)
In schneiderops.xml I think the OiD is :
state
OPS_ETL_STATUS
.1.3.6.1.4.1.318.1.2.2.1.5.0
etl_status_enummap
and the result for this oid (1.3.6.1.4.1.318.1.2.2.1.5.0) in the walkfile is :
1.3.6.1.4.1.318.1.2.2.1.5.0   , Integer     , 1
In the xml file the status codes for this OiD are:
I Think dce is reading this value and reporting the status for that, I verified the communities (public/private) all are for defect config, I don´t have firewall rules in my virtual machines ...
Any idea about this situation?
Thank you very much.
(CID:132666607)
Ok spezialist I´m just trying to download the 8.2.7 and comment soon...
Thank you.
(CID:132666613)
Tell us, please, did you solve your problem or not?
With respect.
(CID:132670092)
Posted: ‎2020-07-04 08:22 PM . Last Modified: ‎2023-10-22 01:29 AM
