Adding client name in DCO colo
  • EcoStruxure IT forum
  • Adding client name in DCO colo
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 09:33 AM . Last Modified: ‎2024-04-10 01:11 AM
708
how do you add a new client name to the company field in the co lo version
(CID:93193448)
  • Data Center Operation
Hi Pete,
Data Center Operation is designed to support integration with your client CRM database through webservices.
Information how to configure this can be seen here:
http://dcimsupport.apc.com/display/DCIMDEVELOPER/CustomerWebService
If you  want to add a client name without without an integration to a CRM database is it also possible. You will then have to use a tool like for instance SoapUI to make the webservice calls to add the client name.
Jesper
(CID:93193457)
Hi peter.e.morris
I have a video tutorial about REST API which explains how to add a user. You could use the same scripts to add a customer:
Introduction to REST API
At 2:05 look for "customers: Customer Service" and in your scripts use the operations from this service.
(CID:108826533)
Posted: ‎2020-07-02 09:33 AM . Last Modified: ‎2023-10-31 10:13 PM
