Posted: 2020-07-04 06:16 PM . Last Modified: 2024-04-04 11:39 PM
I have a customer that is currently running the DCO tenant portal and granting access to customers and internal users/admins from outside of their corporate network. This provider has asked if it would be somehow possible to block access to the "administration" tab in the WebUI if accessed from outside of the corporate network regardless of a users credentials. Any input would be greatly appreciated.
(CID:131966881)
Please advise if additional clarifying information is needed.
Thank you,
(CID:132647634)
There is no way to block access to the "administration" menu in the webUI apart from removing those permissions from the user - it cannot be based on whether the user is accessing the system from outside of the corporate network.
(CID:132649267)
Posted: 2020-07-04 06:17 PM . Last Modified: 2024-04-04 11:39 PM
Do you happen to know if a firewall can be configured to block certain URL's i.e https://
(CID:132650912)
I do not know if that is possible.
(CID:132650970)
Posted: 2020-07-04 06:17 PM . Last Modified: 2023-10-20 04:58 AM
