Dear Community Members, We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience. SE Community Team!
Posted: 2020-07-05 05:19 PM . Last Modified: 2024-04-03 03:24 AM
We have 2 Switchgear which feed our Cooling Units via an ATS.
Switchgear A and Switchgear B both power the ATS which in turn power the Cooling Unit.
Using the Generic ATS genome, I can set the power dependancy from the ATS to a primary connection of Switchgear A and a secondary connection of Switchgear B, which is great (as previously they could only be powered from one source), however, I am unable to power the cooling unit from the ATS.
The genome suggests that the ATS has a Dist panel, but there are no properties in order to create a distribution panel. Assuming that this is why I can't power the cooling unit?
I have also tried to power single feed devices via an ATS (i.e. a Distribution Board), however am finding similar results. I assume this is due to the lack of a breaker panel in the genome?
(CID:140219010)
Hi Sean,
I don't think equipment (such as cooling units) can be powered/connected directly to an ATS device (as power supply). You might want to add a PDU between cooling unit(s) and ATS.
Kind regards
(CID:140712759)
Posted: 2020-07-05 05:19 PM . Last Modified: 2023-10-20 04:57 AM
