How to set a static IP address on the private network of the Gateway appliance (LAN2 or Gb2) - version 1.9 and older
EcoStruxure IT Gateway appliance version 1.9 and older
Support for EcoStruxure IT Gateway Appliances ends in December 2023. Learn how you can migrate to a new installation of the Gateway software.
  • EcoStruxure IT Help Center
  • Gateway
  • EcoStruxure IT Gateway appliance
  • EcoStruxure IT Gateway appliance version 1.9 and older
  • How to set a static IP address on the private network of the Gateway appliance (LAN2 or Gb2) - version 1.9 and older
  • Mark as Read
  • Managing DHCP on the Gateway appliance - version 1...
  • How to set a static IP address on the public netwo...
  • How to set a static IP address on the private netw...
  • Gateway appliance troubleshooting tools - version ...
EcoStruxure IT Support
Request Support
Back to EcoStruxure IT Gateway appliance version 1.9 and older
  • Mark as Read
Picard EcoStruxureIT
‎2019-07-15 06:47 AM
The Gateway appliance private LAN subnet must be 192.168.x.x.
You must contact support to change the Gateway appliance private LAN subnet to anything other than 192.168.x.x.
See Can I change the default subnet for the Gateway appliance private LAN?
Connect a laptop to the private network (LAN2 or Gb2) on the Gateway appliance,.
Confirm that your laptop received a DHCP address from the Gateway. Its address will be 192.168.x.x.
Open a browser on your laptop.
Go to https://192.168.0.1:10000 to connect to Webmin and log in.
Select System configuration > Network Configuration, and then Network Interfaces.
Select the Activated at Boot tab.
Change the IPv4 setting from DHCP to Static configuration and enter the desired IPv4 address and Netmask on the 192.168.x.x subnet only.
Click Save and Apply.
At this point you will lose your connection with Webmin. Reconnect using the new IP address you just configured on the private network.
