Need DDF file for Uniflair (LDCV1400A)
Send InviteCancel
It's hard to tell from the list whether that specific model is supported. DDFs usually cover a device family. Sometimes models can have different network cards so require more than one DDF.
Your best option is to use this form to submit an Asset Definition Request with an attached SNMP walk of the device to determine whether that exact model is supported. SNMP walk instructions
If you haven't already, you could try to discover the device in DCE to see whether it is supported.
By the way, your DCE version is quite old. The current version is 9.0. You can see DCE release notes and pertinent other articles here.
