Posted: 2025-12-12 03:39 PM
How do I generate a Report to list all NIC Models installed on all UPSs in my environment that have NICs installed?
I have tried everything I can think of in the Reports and Monitoring features. Maybe there is a cmd line tool that I'm not aware of? Or, perhaps a newer version offers this report? Presently, we are using EcoStructure IT Data Center Expert 8.2.0
Any advise would be welcome. Thank you!
Posted: 2025-12-15 08:34 AM
Hi @Skylynk ,
Sorry, DCE doesn't have a sensor for which NIC is installed in which device. That being said, if there is no sensor, you can't run a report based on values we don't show.
That being said, there's a manual way that you can at least show the value on the Monitoring / device view perspective. You can create a custom property and manually enter which NMC is installed to that device.
If you look at the hardware, the models are there.
If you want to try to figure out what you have based on firmware revisions, it's not exactly straight forward but this should point you in the right direction:
NMC 1, AP9617/18/19
3 digits starting with either 2.x.x or 3.x.x
NMC2, AP9630/31
3 digits starting with either 5.x.x,6.x.x or 7.x.x
NMC3 AP9640/41
4 digits starting with either 1.x.x.x, 2.x.x.x, 3.x.x.x (3.x firmware requires DCE support contract to get firmware updates from DCE Entitlements Portal)
Steve
Posted: 2026-01-28 01:40 AM
Most UPS vendors have their own monitoring solution which is the preferred method as it will be the most accurate / have the most control.
