ViewX API Documentation
Select a Country
  • Remote Operations
  • ViewX API Documentation
sbeadle
sbeadle Champion
335
AndrewScott
AndrewScott
125
BevanWeiss
BevanWeiss
103
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
Clearscada_EIT
Clearscada_EIT
Explorer
Posted: ‎2022-11-16 09:38 AM . Last Modified: ‎2023-05-02 11:51 PM
3193
I'm not sure if anyone knows where to look for the instruction for all methods, properties for ViewX API ?
The one like the ClearScada.Client API?
thanks
  • ViewX
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
AndrewScott
AndrewScott
Leader
Posted: ‎2022-11-16 10:55 AM
In response to Clearscada_EIT
1
3172
The ListAnimations example, https://github.com/GeoSCADA/Utilities-and-Examples/tree/main/ListAnimations is using the ViewX COM automation interface in the "Serck Controls ViewX Object Library" type library. There is no documentation for this library, just the COM metadata, as its not officially supported.
If you open the ListAnimations solution in Visual Studio you can use the Object Browser to examine the "Interop.ViewX" assembly and see the classes, methods, properties etc. that are available.
References in VS2022References in VS2022Object Browser in VS2022Object Browser in VS2022
Andrew Scott, R&D Principal Technologist, AVEVA
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Replies 4
AndrewScott
AndrewScott
Leader
Posted: ‎2022-11-16 09:57 AM
3185
The documentation is installed with Geo SCADA, look for the "EcoStruxure Geo SCADA \ Client API Guide" shortcut in the Windows start menu.
NB. The "Data Access" feature must be installed to get this documentation.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Clearscada_EIT
Clearscada_EIT
Explorer
Posted: ‎2022-11-16 10:19 AM
In response to AndrewScott
3182
Thanks for the response
I did have the Client API Guide installed ( attach screenshot). However, that guide only shows Clearscada Client API. I'm looking for ViewX API.
For example, i'm looking at C# ListAnimation script in
https://github.com/GeoSCADA/Utilities-and-Examples/blob/main/ListReferences/Program.cs
inside the script, ViewX.DrwAnimation , ViewX.DrwEmbeddedList , ViewX.DrwObject method were used, but i can not find any document that's explaining where to get all these methods and what they are used for
thanks
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
AndrewScott
AndrewScott
Leader
1
3173
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Clearscada_EIT
Clearscada_EIT
Explorer
Posted: ‎2022-11-16 11:14 AM
Thank you for your promptly response
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
