Simple DDK Driver - Intermittent DriverScanner COMException
  • Remote Operations
  • Simple DDK Driver - Intermittent DriverScanner COMException
sbeadle
Kirk sbeadle Kirk
319
AndrewScott
Admiral AndrewScott
114
BevanWeiss
Spock BevanWeiss
97
barrett777
Ensign barrett777
Ensign
Posted: ‎2024-11-13 10:02 AM . Last Modified: ‎2024-11-13 10:04 AM
815
Hi GeoScada Community,
I'm trying to fix an intermittent driver crash, for SE.GeoSCADA.DDK 6.85.8650.  It happens roughly every 1.5 days.
I'm using the DriverApp provided by DriverScanner<> class, for example:
2024-11-13 01:23:02.8267 ServiceHost System.Runtime.InteropServices.COMException (0x80010006): The connection terminated or is in a bogus state and cannot be used any more. Other connections are still valid. (Exception from HRESULT: 0x80010006 (RPC_E_CONNECTION_TERMINATED))
at System.Runtime.InteropServices.Marshal.ThrowExceptionForHRInternal(Int32 errorCode, IntPtr errorInfo)
at ClearSCADA.DriverFramework.DriverApp.SendReceiveObject(UInt32 ObjectId, UInt32 Type, Object DataObject)
 I'm wondering what I should be doing in this situation?
Firstly, am I doing something wrong for this to occur, or is this a connection error that can happen in normal situations?
If this occurs, should I wait and retry the same request with this same connection?
Or should I create a new DriverApp?  If so, should I attach the new DriverApp to the DriverScanner<>?
  • Drivers
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
barrett777
Ensign barrett777
Ensign
Posted: ‎2024-12-11 09:01 AM
Well we upgraded to the Geoscada 2022 - Aug 2024 update and it seems to have fixed my driver issue, without making any changes to the driver.  It's been about 1 week without crashes or any of the COM issues I had seen previously.  So I think I am good now.
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2024-11-29 07:37 AM
It's not clear if this might be related to your code communicating externally or to the driver communicating to the server.
barrett777
Ensign barrett777
Ensign
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2024-12-12 03:05 AM
It's possible that the error has been resolved by the upgrade, so I have marked that as the solution.
