Signal Coloring According to Communicaton State in Map
Send InviteCancel
Posted: 2022-12-1902:47 AM. Last Modified: 2023-05-0211:49 PM
I configured the map in Geo SCADA Expert 2021. I can view the map according to the alarm status. For example if the station has acknowledged alarms, it blinks green. The station has unacknowledged alarms, it blinks red and if it has no alarm, it's color is black. I'm sharing an example screenshot about this situation.
But i need to make some change in this map. Coloring should be based on communication status, not alarm. I mean if the communication is healthy, the station will blink green and otherwise it will red.
I attach the query i use now. What can i fix in this SQL query?
