How to set NoteText for an object in GEOSCADA using python
  • Remote Operations
  • How to set NoteText for an object in GEOSCADA using python
sbeadle
Kirk sbeadle Kirk
311
AndrewScott
Admiral AndrewScott
101
BevanWeiss
Spock BevanWeiss
94
AdamWoodlandToo
Lt. Commander AdamWoodlandToo
38
EcoStruxure™ Geo SCADA Expert
BGedco2022
Lt. Commander BGedco2022
Lt. Commander
Posted: ‎2022-12-13 10:39 PM . Last Modified: ‎2023-05-02 11:49 PM
1286
We're using python to add a note to a group instance in Geo SCADA using the .Net Client API.
as mentioned in the documentation
gObj = connection.GetObject("object fullname")
gObj.Notes = "sss" #AttributeError: 'NoneType' object has no attribute 'Notes'
but Notes did not work
Is there different way when using client API with python? How?
If yes, Where can we find it's documentation?
Appreciate any help
Thanks in advance
  • RTU
  • SCADA
  • Scripting
  • Telemetry
  • ViewX
  • Crystal Reports
  • Geo SCADA
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2022-12-14 12:30 AM . Last Modified: ‎2022-12-14 12:35 AM
Only some properties such as id and FullName are immediate properties of the object. Others require:
P = connection.GetObject("Test")
P["NoteText"] = "test"
Documentation is installed on your PC - see start menu "Client API Guide".
Properties such as NoteText can be seen in the schema browser.
sbeadle
Kirk sbeadle Kirk
Kirk
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2022-12-14 08:39 PM
NoneType is the Python equivalent of a null reference.
You have not provided a valid object reference.
You need to provide more of your code for us to tell you what you're doing wrong.  If you do:
print connection
what do you get?
and then:
print gObj
Perhaps you just don't have a valid object called "object fullname"..
I actually thought that it was FindObject when passing the fullname, and GetObject when passing the ObjectId.
This is a heading
