Resetting ViewX Options
Select a Country
  • Remote Operations
  • Resetting ViewX Options
sbeadle
sbeadle Champion
336
AndrewScott
AndrewScott
127
BevanWeiss
BevanWeiss
104
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
tkswathik
tkswathik
Contributor
Posted: ‎2020-08-12 03:33 PM . Last Modified: ‎2023-05-03 12:12 AM
2260
Is there a way to reset the Guest user options in ViewX. I disabled every setting available to the guest user thinking it might not be needed and also enabled the "restricted workstation" option. I restarted ViewX and logged on ( i have admin privileges), all the explorer options are disabled and I all I can see is a blank viewX screen. The "options" field is disabled as well. I tried removing ViewX and re-installing it but it didn't reset the settings.
Is there a config file or registry setting I can tweak to get this working?
  • ViewX
BevanWeiss
BevanWeiss
Champion
Posted: ‎2020-08-12 06:23 PM
2254
The 'Options' setting is a per-Windows-user setting, in the:
C:\Users\{USERNAME}\AppData\Local\Schneider Electric\ClearSCADA
path... I believe it's called "ViewX Global Settings.dat"
You could just close ViewX, delete that folder and start up ViewX again.  It should recreate it again from the 'Default' user profile if such a file exists there, or from the Schneider default otherwise.
BevanWeiss
BevanWeiss
Champion
2255
tkswathik
tkswathik
Contributor
Posted: ‎2020-08-17 02:33 PM
In response to BevanWeiss
@BevanWeiss
Thanks for the reply. It worked for me
