Posted: 2025-11-27 05:35 AM
Hello, i would like to find unused datapoints in our Geoscada environment.
i want to find all datapoints that are not referenced bij an other object, they can have a reference to another object, most cases is this an outstation.
can someone help me with a query to achieve this?
other tips to achieve this are also welcome.
Greetings,
Johnny Bos
Posted: 2025-12-04 03:35 AM
Perhaps check for errors, as points with missing outstation links will show up. In SQL, check the field ConfigValid.
You can use Python or C# with the APIs to chase references.
Examples:
2023 Pythonnet: https://github.com/GeoSCADA/Utilities-and-Examples/blob/main/PythonSamples/ListAllReferencesToGroup....
2025 Native Python: https://github.com/GeoSCADA/Python-Geo-SCADA-Client-Samples/blob/main/ListAllReferencesToGroup.py
Posted: 2025-12-03 05:43 AM
Years ago I had asked the same question and there was no way. I asked for this feature to be added but as far as I know it has not. it is probably a bit complex and could probably lock the system for way to long.
As far as I know the only way to check references is by right clicking on a point and selecting the the referenced by option.
Examples:
Posted: 2025-12-04 05:55 AM
I think it'd be neat if objects simply had an integer value that represented the number of objects that referred to it.
Posted: 2025-12-04 10:27 PM
Hello, thank you for these responses. This confirms to me that it’s difficult or impossible to display this in a simple way. I’ll take a look at the Python scripts to see if I can do something with them; otherwise it will have to be checked manually. Tfranklin’s suggestion would have helped me if that option were available — maybe a feature request.
Posted: 2025-12-08 05:28 AM . Last Modified: 2025-12-08 05:29 AM
Yeah a simple reference counter would be useful.
Just like when currently checking a single objects references we'd have to keep in mind that a script could reference something and that would not be included in the reference list.
