Manual alarm redirections list order
Showing results forΒ
Did you mean:Β
  • Remote Operations
  • Manual alarm redirections list order
sbeadle
Kirk sbeadle Kirk
318
AndrewScott
Admiral AndrewScott
109
BevanWeiss
Spock BevanWeiss
96
AdamWoodlandToo
Lt. Commander AdamWoodlandToo
39
AppSupport
Ensign AppSupport
Ensign
Posted: β€Ž2025-06-25 03:33 AM
384
Hi all, what determines the order in which manual alarm redirection actions are displayed on the context-sensitive list? We can't figure out how to reorder these πŸ˜›
  • SCADA
  • ViewX
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
AndrewScott
Admiral AndrewScott
Admiral
Posted: β€Ž2025-06-26 04:41 AM
The current ordering is a side effect of the deduplicating algorithm that ensures each action only appears once in the list. This isn't the best ordering for the user interface. Sorting them alphabetically by description would be better for the user interface.
You could make a suggestion in the ideas section of this forum:
https://community.se.com/t5/forums/postpage/choose-node/true/board-id/geo-scada-expert-ideas
Andrew Scott, R&D Principal Technologist, AVEVA
AndrewScott
Admiral AndrewScott
Admiral
Posted: β€Ž2025-06-25 06:23 AM
381
They are sorted into redirection action database object creation order, oldest first, newest last.
AppSupport
Ensign AppSupport
Ensign
Posted: β€Ž2025-06-26 02:35 AM
In response to AndrewScott
Thanks for the quick response, Andrew, much appreciated.
So we are essentially saying that to, for example, bump a new one up to the top of the list, we would have to delete/recreate all of the other existing manual redirection action objects?
If this is the case, may I suggest that an improvement be put forward to include a method of doing this?
Thanks and regards πŸ™‚
AndrewScott
Admiral AndrewScott
Admiral
Β
