Posted: 2025-01-08 03:28 AM
Hello all, best wishes in new year.
I have simple questions
Q1 - is there any way how to force Json A to accept string
Q2 - is there any way how to force Json A to convert published value as a string and covert it into number?
Description of my problem
I have JSON that looks like that
"main":
"value": "868.9640",
"raw": "00868.9640",
"pre": "868.9640",
"error": "no error",
"rate": "0.000060",
"timestamp": "2024-12-18T18:27:05+0100"
And i want to receive the tag VALUE. But its represented as a string. And there is no string point in CSE 2022 (23 update 85.8650) and analog point is not accepting that format. While HomeAssistant has no problem with that (but i am not using that).
My Mqtt broker is Mosquitto as i found big help in one of Steve's videos on youtube.
When i used Mqtt browser and force to pretend that he received the JSON in this format
"main":
"value": 868.9640,
"pre": "868.9640",
"rate": "0.000060",
I can get the value into analog point easily.
Posted: 2025-01-08 07:39 AM
Sorry, no. But the new Text/JSON driver in Geo SCADA 2023 might do it?
Posted: 2025-01-09 02:02 AM . Last Modified: 2025-01-10 12:49 AM
Ok, i'll give a try
EDIT:
yes the new driver helped and work with strings. Now i can easily convert the string into value. Thank you Mr Steve.
