MQTT Driver in Geo SCADA Expert 2019
  • Remote Operations
  • MQTT Driver in Geo SCADA Expert 2019
sbeadle
Kirk sbeadle Kirk
323
AndrewScott
Admiral AndrewScott
118
BevanWeiss
Spock BevanWeiss
100
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
vpartinov
Crewman vpartinov
Crewman
Posted: ‎2020-06-18 01:28 AM . Last Modified: ‎2023-05-03 12:13 AM
5011
Someone having problems with the new MQTT JSON Schema A driver?
I decided to test it, so everything works fine until I found out the data is not stored into historian. The configuration, the broker, the json format, everything is fine, even in the log files it recognizes the values and timestamps, it associated the topics, items and points. No error in the log files but there are nothing in the historian of the points. Also in ViewX the connection with broker is good, but for the current values of the points there are nothing (Waiting for initial data) even though in the log file says that there are data for these points.
  • Drivers
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2020-06-18 08:38 AM
4982
It could be that the data format is incorrect? The format requires a timestamp value and point names/values. If there is no timestamp then data will not be processed.
An example is:
    "time": 1592493746,
    "Analog1": 51
The time is a 'unix epoch' number of seconds since 1 Jan 1970, and the point 'Tag' field should be "Analog1" in this case.
Replies 11
sbeadle
Kirk sbeadle Kirk
Kirk
4983
An example is:
    "time": 1592493746,
    "Analog1": 51
Rich-C
Lieutenant JG Rich-C
Lieutenant JG
Posted: ‎2022-08-25 12:36 PM
In response to sbeadle
4017
So I am having the same issues I cant get values to show even though my broker and device are showing healthy communication.
I have 3 sensors Temperature & Humidity , Moisture and C02 values I am trying to show.
How can I check to see if Geo SCADA is pulling the data?
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2022-08-26 02:34 AM
In response to Rich-C
4001
Please check the driver log file, usually at:
C:\ProgramData\Schneider Electric\ClearSCADA\Logs\Drivers\DriverMQTT_001.log (and 002, ...)
The JSON needs to be formatted correctly, and the point configuration needs to match the point names in the JSON string.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Rich-C
Lieutenant JG
Posted: ‎2022-08-29 11:27 AM
3968
Hello, Sbeadle
Thanks for the response.
might need a little more assistance with matching the JSON string with Tag in GeoSCADA.
So, after reviewing the logs I can see the ID, class, state and name of the points. what do I have to match in geoscada?  below is the log maybe you can advise me which one?
Thanks again..
Logging started at 25-AUG-2022 20:27:44.958 (UTC)
File : C:\ProgramData\Schneider Electric\ClearSCADA\Logs\Drivers\DriverMQTT_001.log
System : Microsoft Windows 10 Professional Edition, 64-bit (10.0.19044)
CPU : 1 x Intel Unknown Family 6, Model 165, Stepping 2
Intel(R) Core(TM) i7-10750H CPU @ 2.60GHz
ClearSCADA Core : Build 6.83.8017.1 (Release)
Local time zone : UTC-04:00 (Daylight)
Process ID : 16388
Computer : RICH-LAPTOP
Driver : MQTT
Started : 25-AUG-2022 20:27:44.668
Uptime : 0 00:00:00.291
Logging options:
APP : Application
ERR : Errors
OBJ : Database Objects
PNT : Points
REQ : Requests (Actions)
DAT : Point Updates (Data)
PER : Paho Errors
Threads:
16392 : Main
Registry settings:
HKEY_LOCAL_MACHINE\Drivers\ErrorMsgBox = False
HKEY_LOCAL_MACHINE\Drivers\HeartbeatEavesdrop = False
HKEY_LOCAL_MACHINE\Drivers\ServerPollInterval = 5000
HKEY_LOCAL_MACHINE\Drivers\AsyncPointRequests = True
HKEY_LOCAL_MACHINE\Drivers\SecondaryDataMaxPointUpdates = 250
HKEY_LOCAL_MACHINE\Drivers\MaxPendingAsyncPointRequests = 300
HKEY_LOCAL_MACHINE\Drivers\ValueMapScanningInterval = 1000
HKEY_LOCAL_MACHINE\Drivers\SelectBestChannel = False
HKEY_LOCAL_MACHINE\Drivers\BreakDuration = 100
HKEY_LOCAL_MACHINE\Drivers\PostHangupDelay = 0
HKEY_LOCAL_MACHINE\Drivers\TimeJumpLimit = 50
HKEY_LOCAL_MACHINE\Drivers\RequestTimeout = 600
HKEY_LOCAL_MACHINE\Drivers\RequestTimeoutExtn = 300
HKEY_LOCAL_MACHINE\Drivers\ScannerCommandTimeout = 30
HKEY_LOCAL_MACHINE\Drivers\ScannerRequestTimeout = 180
HKEY_LOCAL_MACHINE\Drivers\EavesdropPSTNTimeout = 30
HKEY_LOCAL_MACHINE\Drivers\RxFailureLimit = 10
HKEY_LOCAL_MACHINE\Drivers\TxFailureLimit = 10
HKEY_LOCAL_MACHINE\Drivers\RetryAssignInterval = 30
HKEY_LOCAL_MACHINE\Drivers\RxTimeoutLimit = 20
HKEY_LOCAL_MACHINE\Drivers\TxTimeoutLimit = 20
HKEY_LOCAL_MACHINE\Drivers\GracefulSocketCloseTimeout = 1000
HKEY_LOCAL_MACHINE\Drivers\AllowInboundConFromAllOS = False
HKEY_LOCAL_MACHINE\Drivers\DirectOnDemandRetryPeriod = 120
HKEY_LOCAL_MACHINE\Drivers\PortServerSettingsTimeout = 10
HKEY_LOCAL_MACHINE\Drivers\ComtrolFreeportDelay = 250
HKEY_LOCAL_MACHINE\Drivers\MaxBatchWriteSize = 1000
HKEY_LOCAL_MACHINE\Drivers\ListenPortRangeStart = 0
HKEY_LOCAL_MACHINE\Drivers\ListenPortRangeEnd = 0
HKEY_LOCAL_MACHINE\Drivers\ResolveNameRetryInterval = 300
HKEY_LOCAL_MACHINE\Drivers\ResolveNameRetryTimeLimit = 10
HKEY_LOCAL_MACHINE\Drivers\PointStatInterval = 4
HKEY_LOCAL_MACHINE\Drivers\PointStatTopX = 25
HKEY_LOCAL_MACHINE\DriverMQTT\LogEnableTelnet = False
25-AUG-2022 20:27:46.280 [Main] Database classes (21)...
Name |Type
CProfile |Resource
CProfileFloat |Resource
CProfileULong |Resource
CProfileLong |Resource
CAdvBITValueMap |Resource
CAdvBYTEValueMap |Resource
CAdvWORDValueMap |Resource
CAdvDINTValueMap |Resource
CAdvUDINTValueMap |Resource
CAdvREALValueMap |Resource
CAdvDOUBLEValueMap |Resource
CAdvStringValueMap |Resource
CDynacardStore |Resource
CAdvOutstation |Modem
CSSLCertificate |Resource
CSSLCertificateAndKey |Resource
CMQTTBroker |Channel
CJSONSchemaAPntDigital |Point
CJSONSchemaAPointAnalog |Point
CJSONSchemaAPntCounter |Point
CJSONSchemaADevice |Outstation
25-AUG-2022 20:27:46.287 [Main] Creating all objects
25-AUG-2022 20:27:46.287 [Data Cache] Started new thread (ID=18116)
25-AUG-2022 20:27:46.288 [Main] Creating objects for class "CMQTTBroker"
25-AUG-2022 20:27:46.288 [Main] Creating "Demo.Aranet.MQTT.New Broker" [CMQTTBroker,7524]
25-AUG-2022 20:27:46.289 [Main] Finished creating objects for class "CMQTTBroker", 1 Objects
25-AUG-2022 20:27:46.289 [Main] Creating objects for class "CJSONSchemaAPntDigital"
25-AUG-2022 20:27:46.290 [Main] Finished creating objects for class "CJSONSchemaAPntDigital" 0 Objects
25-AUG-2022 20:27:46.290 [Main] Creating objects for class "CJSONSchemaAPointAnalog"
25-AUG-2022 20:27:46.290 [Main] Creating "Demo.Aranet.MQTT.Co2" [CJSONSchemaAPointAnalog,7529]
25-AUG-2022 20:27:46.291 [Main] Creating "Demo.Aranet.MQTT.Temperature and Humidity" [CJSONSchemaAPointAnalog,7526]
25-AUG-2022 20:27:46.291 [Main] Finished creating objects for class "CJSONSchemaAPointAnalog", 2 Objects
25-AUG-2022 20:27:46.292 [Main] Creating objects for class "CJSONSchemaAPntCounter"
25-AUG-2022 20:27:46.292 [Main] Creating "Demo.Aranet.MQTT.Moisture" [CJSONSchemaAPntCounter,7527]
25-AUG-2022 20:27:46.293 [Main] Finished creating objects for class "CJSONSchemaAPntCounter", 1 Objects
25-AUG-2022 20:27:46.293 [Main] Creating objects for class "CJSONSchemaADevice"
25-AUG-2022 20:27:46.294 [Main] Creating "Demo.Aranet.MQTT.Aranet" [CJSONSchemaADevice,7525]
25-AUG-2022 20:27:46.305 [Main] Finished creating objects for class "CJSONSchemaADevice", 1 Objects
25-AUG-2022 20:27:46.305 [Main] Finished creating all objects
25-AUG-2022 20:27:46.305 [Main] Initialising all objects
25-AUG-2022 20:27:46.309 [Main] (id=7524) SubObj:Demo.Aranet.MQTT.Aranet(id=7525) CDrvMQTTSubscriptionObject::SetSubscriptionState() Disconnected to SUBSCRIBE Pending Healthy Connection
25-AUG-2022 20:27:46.311 [Main] Paho {3} =========================================================
25-AUG-2022 20:27:46.311 [Main] Paho {3} Trace Output
25-AUG-2022 20:27:46.311 [Main] Paho {3} Product name: Eclipse Paho Asynchronous MQTT C Client Library
25-AUG-2022 20:27:46.311 [Main] Paho {3} Version: 1.3.0
25-AUG-2022 20:27:46.311 [Main] Paho {3} Build level: 2019-04-10T12:19:29Z
25-AUG-2022 20:27:46.311 [Main] Paho {3} OpenSSL version: OpenSSL 1.1.0j 20 Nov 2018
25-AUG-2022 20:27:46.311 [Main] Paho {3} OpenSSL flags: compiler: cl
25-AUG-2022 20:27:46.311 [Main] Paho {3} OpenSSL build timestamp: built on: reproducible build, date unspecified
25-AUG-2022 20:27:46.311 [Main] Paho {3} OpenSSL platform: platform: VC-WIN64A
25-AUG-2022 20:27:46.311 [Main] Paho {3} OpenSSL directory: OPENSSLDIR: "D:\dev\SDKs\OpenSSL\misc\64DR"
25-AUG-2022 20:27:46.338 [Main] a18ca05564134879ab3e29cd0971334f.s2.eu.hivemq.cloud:8883,clientId-x73hOp0W7i CDrvMQTTBroker::SetConnectionState() Disconnected to Starting
25-AUG-2022 20:27:46.338 [Main] a18ca05564134879ab3e29cd0971334f.s2.eu.hivemq.cloud:8883,clientId-x73hOp0W7i CDrvMQTTConnection::Connect()
25-AUG-2022 20:27:46.339 [Main] Finished initialising all objects
25-AUG-2022 20:27:46.339 [Main] Database objects (5)...
Id|Class |State |Reqs|Rply|Name
7524|CMQTTBroker |Synced | 0| 0|Demo.Aranet.MQTT.New Broker
7525|CJSONSchemaADevice |Synced | 0| 0|Demo.Aranet.MQTT.Aranet
7526|CJSONSchemaAPointAnalog |Synced | 0| 0|Demo.Aranet.MQTT.Temperature and Humidity
7527|CJSONSchemaAPntCounter |Synced | 0| 0|Demo.Aranet.MQTT.Moisture
7529|CJSONSchemaAPointAnalog |Synced | 0| 0|Demo.Aranet.MQTT.Co2
25-AUG-2022 20:27:47.924 [18152] a18ca05564134879ab3e29cd0971334f.s2.eu.hivemq.cloud:8883,clientId-x73hOp0W7i CDrvMQTTConnectListener::on_success()
25-AUG-2022 20:27:47.924 [18152] Sending event MQTT connect request succeeded to "Demo.Aranet.MQTT.New Broker" from scanner
25-AUG-2022 20:27:47.924 [Main] a18ca05564134879ab3e29cd0971334f.s2.eu.hivemq.cloud:8883,clientId-x73hOp0W7i CDrvMQTTBroker::SetConnectionState() Starting to Healthy
25-AUG-2022 20:27:47.925 [Main] a18ca05564134879ab3e29cd0971334f.s2.eu.hivemq.cloud:8883,clientId-x73hOp0W7i Subscribing to topic "Aranet"(Id=7525) using QoS 1
25-AUG-2022 20:27:47.925 [Main] a18ca05564134879ab3e29cd0971334f.s2.eu.hivemq.cloud:8883,clientId-x73hOp0W7i(id=7524) SubObj:Demo.Aranet.MQTT.Aranet(id=7525) CDrvMQTTSubscriptionObject::SetSubscriptionState() SUBSCRIBE Pending Healthy Connection to Waiting For SUBACK
25-AUG-2022 20:27:48.048 [18152] a18ca05564134879ab3e29cd0971334f.s2.eu.hivemq.cloud:8883,clientId-x73hOp0W7i CDrvMQTTSubscribeListener::on_success()
25-AUG-2022 20:27:48.048 [18152] Sending event MQTT subscribe ack to "Demo.Aranet.MQTT.New Broker" from scanner
25-AUG-2022 20:27:48.048 [Main] a18ca05564134879ab3e29cd0971334f.s2.eu.hivemq.cloud:8883,clientId-x73hOp0W7i(id=7524) SubObj:Demo.Aranet.MQTT.Aranet(id=7525) CDrvMQTTSubscriptionObject::SetSubscriptionState() Waiting For SUBACK to SUBSCRIBE Succeeded
25-AUG-2022 20:27:48.048 [Main] a18ca05564134879ab3e29cd0971334f.s2.eu.hivemq.cloud:8883,clientId-x73hOp0W7i CDrvMQTTSubscriptionObject::HandleSubscriptionAck() succeeded
26-AUG-2022 08:27:44.229 [Main] a18ca05564134879ab3e29cd0971334f.s2.eu.hivemq.cloud:8883,clientId-x73hOp0W7i CDrvMQTTConnection::Disconnect()
26-AUG-2022 08:27:44.229 [Main] a18ca05564134879ab3e29cd0971334f.s2.eu.hivemq.cloud:8883,clientId-x73hOp0W7i CDrvMQTTBroker::SetConnectionState() Healthy to Stopping
26-AUG-2022 08:27:44.230 [18148] a18ca05564134879ab3e29cd0971334f.s2.eu.hivemq.cloud:8883,clientId-x73hOp0W7i CDrvMQTTDisconnectListener::on_success()
26-AUG-2022 08:27:44.230 [18148] Sending event MQTT disconnect request succeeded to "Demo.Aranet.MQTT.New Broker" from scanner
26-AUG-2022 08:27:44.435 [Data Cache] Thread terminated (ID=18116)
26-AUG-2022 08:27:44.438 [Main] Driver stopped after 0 11:59:59.770
Logging stopped at 26-AUG-2022 08:27:44.438 (UTC)
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2022-08-30 02:38 AM
3959
Check both your topic name and the tag name. The Tag name in the JSON must match the point configuration.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Rich-C
Lieutenant JG
Posted: ‎2022-09-02 09:03 AM
3916
I need some assistance with adding the geoscada node..I am stuck from moving the box files from github to my pc local folder step.
Place the files from the Box folder here into a working folder. I used:??????????????????????????????????
Install Node-Red
This guide is for Windows, on other platforms, please find instructions on the Node and Node-Red web sites.
Install Node
  1. Go to https://nodejs.org/en/#home-downloadhead and select the LTS version (currently 12.18.4 LTS) to download.
  2. Install this – you will then be directed to install the Additional Tools – this may work, but if not and you see "The request was aborted: Could not create SSL/TLS secure channel", then you need to follow these steps for the additional tools:
    1. Download and install the latest Powershell from: https://github.com/PowerShell/PowerShell
    2. Edit the file: "C:\Program Files\nodejs\install_tools.bat" and replace "%SystemRoot%\System32\WindowsPowerShell\v1.0\powershell.exe" with "C:\Program Files\PowerShell\7\pwsh.exe" in two places on the last line.
    3. Run this batch file and check for success.
    4. (Link to this additional fix: https://github.com/nodejs/node/issues/33140 )
(These commands may not work through a web proxy or PAC file such as in a company network.)
Install Node-Red
Start "Node.js command prompt" from the Start menu (as Admin). Then enter:
npm install -g --unsafe-perm node-red
This will install node-red, taking a few minutes.
Our node needs a package called xml2js, so also run:
npm install -g --unsafe-perm xml2js
Add the Geo SCADA node
Spoiler
C:\Users\<your user id>\AppData\Roaming\npm\node_modules\node-red
The files are in a subfolder named "node-dev-geoscada":
Then from the Node.js command prompt execute:
npm install C:\Users\Administrator\AppData\Roaming\npm\node_modules\node-red\node-dev-geoscada
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2022-09-05 02:48 AM
3857
Your title implies you want to use MQTT, but the content is from a document describing how to use the Geo SCADA web services with Node-Red. So what do you want to do - MQTT or web services?
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Rich-C
Lieutenant JG
Posted: ‎2022-09-06 07:03 AM
3809
Hello, Mr. sbeadle
I want to configure MQTT in GeoScada but your instructions are not clear to  me I am not a programmer or developer so I was trying to mimic the screenshot you posted and I saw you were using NODE-Red to show the data tag "Analog1" which I don't see in my logs.
I posted my logs of the MQTT driver and you mentioned to match it with the tag in GEOSCADA but the logs do not show the same tag name as the one you have " Analog1".
I have tried to match all 3 tag names from my logs to GEOSCADA and I still don't get DATA.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2022-09-09 06:27 AM
3766
Please see these release notes: https://schneider-electric.box.com/shared/static/2790008bt5j5j5victze9r5cln6bea36.pdf
Find the MQTT section on page 26, and follow the instructions there.
BUT note the command line for mosquitto_pub is incorrect, it should be:
mosquitto_pub -h 127.0.0.1 -p 1883 -t /East\MyDevice1 -m "{\"time\":1559225529, \"Analog1\":12.3}"
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Rich-C
Lieutenant JG
Posted: ‎2022-09-20 01:34 PM
3616
Hello Support,
I have tested moquitto broker and the test was successful with publishing and subscribing the the test data.
I'm still not sure why Geoscada is not getting the data.
Is there a support phone number I can call? or a remote support I can schedule?
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
AndrewScott
Admiral AndrewScott
Admiral
Posted: ‎2022-09-21 01:18 AM
@Rich-C The contact details for customer support are here:
https://community.se.com/t5/Geo-SCADA-Knowledge-Base/Geo-SCADA-Expert-Support/ba-p/279117
Andrew Scott, R&D Principal Technologist, AVEVA
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
