MERGE HISTORIC FILES @GEO SCADA
  • Remote Operations
  • MERGE HISTORIC FILES @GEO SCADA
sbeadle
Kirk sbeadle Kirk
319
AndrewScott
Admiral AndrewScott
114
BevanWeiss
Spock BevanWeiss
97
AdamWoodlandToo
Lt. Commander AdamWoodlandToo
39
EcoStruxure™ Geo SCADA Expert
BGedco2022
Lt. Commander BGedco2022
Lt. Commander
Posted: ‎2022-09-20 02:33 AM . Last Modified: ‎2023-05-02 11:52 PM
1225
Can we merge or copy of historic files of the last 2 years from backup into the current database of GEOSCADA?
If yes, How?
Appreciate any hint
Thanks in advance
  • SCADA
  • Trends
  • ViewX
  • odbc
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
AdamWoodland
AdamWoodland Schneider Alumni (Retired)
Posted: ‎2022-09-20 09:14 PM
Given the hrd files are just chunks of 32-byte records in theory you could just copy two files together into one and that could work. I've never tried it, it is probably not supported, just throwing it out there given your other post about extract historic from backups. It would also be very fast to run, which might be relevant if you have a million or so points to merge,
The proper way to do this would be use to use LoadDataValue, LoadDataValues and LoadDataFile on the CHistoryBase table. This allows you to insert data into the historic. You'll have to read the current historic data, work out what is extra, then insert that back using the relevant method (probably using LoadDataValues)
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
