Logic Execution History
  • Remote Operations
  • Logic Execution History
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
MichaelAur
Ensign MichaelAur
Ensign
Posted: ‎2024-08-14 04:09 PM
942
I was wondering if there is any easy way to record every time that a piece of logic executes. I am asking as we have a logic block that is setup to execute every 1second but only on a change of input state. This then updates some output states. I have historic data turned on for both the input and output and am seeing the input changing state but am sometimes missing the output changing state. I am trying to work out if logic block is not executing for some reason. A such it would be very useful if i could see a record of every time the logic block actually executes.
I thought about adding an extra IO that just toggles state on each execution and watch the historic record of this but that obviously causes a continuous loop as it is an input that is changing.
any ideas or advice would be greatly appreciated. For record we are running Geo Scada Expert 2021 (84.8852)
  • Logic
  • SCADA
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
geoffpatton
Captain geoffpatton
Captain
Posted: ‎2024-08-19 07:15 AM
in existing ST make it Write only %Q and only write a 1 to you extra IO point. Then have another ST program that executes on input processed with just that extra IO point in it and have it just write a 0.
Filter the history to just show you the 1 values.
geoffpatton
Captain geoffpatton
Captain
MichaelAur
Ensign MichaelAur
Ensign
Posted: ‎2024-08-19 09:42 PM
Ahh sometimes the simple option is the best. I was so focused on trying to do it without another logic. But that works well! Thanks.
AdamWoodlandToo
Lt. Commander AdamWoodlandToo
Lt. Commander
Posted: ‎2024-08-20 02:40 AM
If you want to dig deeper, you can enable more Logic logging options in the DB logs, including each time the logic executes and the reading/writing of variables. Very useful if you need to work out why something isn't executing when you're expecting it to (such as due to too many other logic programs queued)
