[Imported] Geo MapSet Centering
  • Remote Operations
  • [Imported] Geo MapSet Centering
sbeadle
Kirk sbeadle Kirk
318
AndrewScott
Admiral AndrewScott
109
BevanWeiss
Spock BevanWeiss
96
AdamWoodlandToo
Lt. Commander AdamWoodlandToo
39
EcoStruxure™ Geo SCADA Expert
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2019-11-06 03:07 PM . Last Modified: ‎2023-05-03 12:25 AM
777
>>Message imported from previous forum - Category:General Items<<
User: dialvec, originally posted: 2019-04-23 21:08:16 Id:416
Hi everybody.
I am using OpenStreetMap Source to center a Map Set. The place I want to focus on is located on:
**Latitude:** 1.61417
**Longitude:** -75.61167
When I open the Map Set, it does not focus on the coordinates. I am using the following configuration:
**Projection name:** EPSG:3116
**Projection Config:** +proj=merc +lat_0=1.61417 +lon_0=-75.61167 +k=1.0 +units=m +nadgrids=[at]null +wktext +no_defs
When I open the Map Set, it shows up centered in 0.0 0,0 despite the configuration.
Any idea?
Thank you so much.
  • SCADA
sbeadle
Kirk sbeadle Kirk
Kirk
Reply From User: JesseChamberlain, posted: 2019-04-24 03:30:30
The projection has nothing to do with the default location - directly anyway. The default location is pulled from the position field on the map set's location tab.
Reply From User: dialvec, posted: 2019-04-24 12:45:55
Thank you very much! That solved it
sbeadle
Kirk sbeadle Kirk
Kirk
