Send InviteCancel
Posted: 2019-10-2503:00 PM. Last Modified: 2023-05-0312:39 AM
[Imported] Generate Report Failed
>>Message imported from previous forum - Category:General Items<< User: mchartrand, originally posted: 2018-10-23 14:00:34 Id:168 This is a re-posting from the obsoleted (October 2018) "Schneider Electric Telemetry & SCADA" forum. -------------------------------
**_Andrew: Hey all, got a strange one here. I created a crystal report and that is exporting to a file server. It exports automatically via ST. That part is working. The issue I am having is when i try to generate the report the view it in viewX it tells me access is denied. Any thoughts?_**
______________________
bevanweiss: Are there any permissions that your user doesn't have? Is Historic enabled for the Report? If not, then I don't believe it stores anything to actually look at.
__________
**_Andrew: In the system configuration/permission restrictions, Retrieve Data is not checked. I do have historic enabled also._**
______________
bevanweiss: Are there other permissions that you're missing?
Try enabling the Retrieve Data... it's a bit driver specific as to what it allows (or doesn't allow). I can't remember if it hasn't any influence on Crystal Reports stuff. The ClearSCADA online help says The Retrieve Data permission defines whether the user or User Group can access the actions that allow the ClearSCADA server to request data from an outstation, PLC etc. For example, if this permission is enabled on a PSTN outstation for the selected user, the user can access the One Shot action. which sounds like I'm completely off-base on this.. but worth a try anyway.
It is definitely a ClearSCADA error box with the Access Denied right? (not like Windows possibly trying to do something, like saving/opening a file locally)
