IIS in GEO SCADA 2021
  • Remote Operations
  • IIS in GEO SCADA 2021
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
BGedco2022
Lt. Commander BGedco2022
Lt. Commander
Posted: ‎2022-08-29 02:22 AM . Last Modified: ‎2023-05-02 11:53 PM
1683
Hello Everyone,
Do we need IIS on GEO SCADA's client machine? if not,
Could it affect ViewX performance and effiency iF we stop it from the client machines ?
Thanks in advance
  • SCADA
  • Telemetry
  • ViewX
geoffpatton
Captain geoffpatton
Captain
Posted: ‎2022-08-29 12:23 PM . Last Modified: ‎2022-08-29 12:40 PM
2
1675
IIS is just for the two newer web servers. No client machines need IIS.
(Edit I forgot to answer this part of your question)
I would not have IIS installed on any computer that does not need. I do not think having IIS installed and it not being used will affect ViewX's performance. There is probably a slight difference in system memory usage.
(End Edit)
you may find this information useful in the future.
The original WebX does not use IIS.
The WebX that is a hybrid of HTML5 and the original WebX's ActiveX uses IIS.
The Virtual ViewX server use ISS.
So where ever one of two are installed requires IIS. If neither of these are installed on the Database server then you do not need IIS on the database server.
The web server for Virtual ViewX can be installed on a separate server than the database server.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
geoffpatton
Captain geoffpatton
Captain
2
1676
(End Edit)
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2022-08-30 02:31 AM
In response to geoffpatton
1
1660
Thank you Geoff,
one extra note - IIS is also required for all server installs of Geo SCADA 2021. This is because the web service port (used by WebX) is also user by ViewX for scripting.
So, unless you are going to either (a) use your own reverse proxy or (b) have no TLS or only TLS 1.1 security on this port, you must install the IIS components for all servers.
Please check the 2021 release notes which explains the setup.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
geoffpatton
Captain geoffpatton
Captain
Posted: ‎2022-08-30 07:49 AM
In response to sbeadle
Thanks Steve I probably would have found that out the hard way since I did not notice that, and the only 2021 I have installed has Virtual ViewX installed with the database server so it has IIS.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
