How to call the ClearSCADA built in Time Average function?
  • Remote Operations
  • How to call the ClearSCADA built in Time Average function?
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
Posted: ‎2020-07-05 09:17 PM . Last Modified: ‎2023-05-03 12:13 AM
2300
Is it possible to call the ClearSCADA Time Average function from a .NET application using the client library? Any example code will be much appreciated.
Thanks a lot.
  • SCADA
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2020-07-06 10:55 PM
2283
Yes, it's possible.
From the .NET API you can InvokeMethods, you just need to know the name of the Method that you want to call, and what aggregate it is on, and what arguments to provide to it.
Pretty much all of these can be found in the DB Schema.
So I would start there.
If you're on your local GeoSCADA Expert server you can probably just go here:
https://localhost/schema/CHistoryBase
And that should show you the methods available.  You can see 'ProcessedValue' which will return 'a single processed historic value', which sounds like what a Time Average would be.
Then if you look at the argument for it, it wants:
  • StartTime (Time)... should be easy
  • EndTime (Time)... should be easy
  • Aggregate (Long)... you probably need to find out what number is associated with the aggregate you want.. I forget where this was found, I think it's in the help somewhere, or tprojects
  • Reason (String).. to filter the values if needed
It will return a variant representing the processed value.
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2020-07-07 02:19 AM
In response to BevanWeiss
2276
Here's some sample code to do that - comments do some of the explaining:
                // Retrieve the last day's data
                DateTime startTime = DateTime.UtcNow.Subtract(TimeSpan.FromDays(1));
                DateTime endTime = DateTime.UtcNow;
                // Retrieve an average of the last day's values - Processed Data
                // Historic Aggregate code 3 = average of values. Search help for "Animations for Historic Data" for codes.
                object[] pParams = new object[4] { startTime, endTime, 3, "" };
                object value = (object)myPoint.InvokeMethod("Historic.ProcessedValue", pParams);
                Console.WriteLine("Processed Average Value: " + value.ToString());
BevanWeiss
Spock BevanWeiss
Spock
2284
Yes, it's possible.
sbeadle
Kirk sbeadle Kirk
Kirk
2277
Posted: ‎2020-07-07 10:00 PM
In response to sbeadle
Time Average = 30
StdDev = 5
Thanks a lot for your help!
