Export ClearSCADA Historic Data
  • Remote Operations
  • Export ClearSCADA Historic Data
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
DavidSkilbeck
Lt. Commander DavidSkilbeck
Lt. Commander
Posted: ‎2020-06-30 04:54 PM . Last Modified: ‎2023-05-03 12:13 AM
4434
Hi, I refer to https://www.se.com/ww/en/faqs/FA312272/.
Where it mentions WKxxxxxx.hrd files.
Can these .hrd files be copied from one GeoSCADA machine and pasted in to the appropriate folder of another. GeoSCADA machine?
(Example of folder path - C:\ProgramData\Schneider Electric\ClearSCADA\Database\History\Historic\HdI02382\609845)
Would the GeoSCADA machine with pasted files, then pick up on these files or would we have to import / configuration?
The ultimate goal of this post is to investigate if .hrd file can be copied over from one GeoSCADA machine and used in another.
  • SCADA
Posted: ‎2020-07-02 06:33 PM
In response to DavidSkilbeck
4396
Sure, you can do it and it will work most of the time, but by doing this method you bypass database locking. Don't raise a case with support when the data is incomplete or corrupted, or the server raises alarms about not being able read historic data!
There are methods built in to do this, use them.
Replies 6
Posted: ‎2020-06-30 06:57 PM . Last Modified: ‎2025-08-12 05:15 AM
4423
In your example, 609845 is the object ID for the point that generated the historic data. Whichever object ID is there on the destination system is the object that the data will be added to. There will need to be an existing point configured with that object ID.
When copying and pasting database files, the system should be stopped to avoid issues with flushing and file access, but as Steve said in the other topic it's not an ideal way to do it.
Have a read of this page on streams.
DavidSkilbeck
Lt. Commander
Posted: ‎2020-07-02 03:57 PM
In response to Anonymous user
4398
Hi, I created a point in one GeoSCADA vm and created a .hrd file for that point.
Then copied the .hrd file over to another GeoSCADA vm where I had created another point of the same name.
Restarted that GeoSCADA and it picked up on the copied file.
In practise stopping the first GeoSCADA machine in order to copy the file would be an issue.
Not so for the second GeoSCADA machine.
4397
DavidSkilbeck
Lt. Commander
Posted: ‎2020-07-06 07:35 PM
4368
Hi, can you please elaborate on "There are methods built in to do this, use them.".
Which methods do you refer to exactly.
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2020-07-06 10:43 PM . Last Modified: ‎2025-08-12 05:15 AM
4361
I reckon Jesse will be talking about these
https://community.se.com/t5/Geo-SCADA-Knowledge-Base/bg-p/geo-scada-knowledge-base
DavidSkilbeck
Lt. Commander
Posted: ‎2020-07-06 10:55 PM
In response to BevanWeiss
Oh, yes. I have used this before.
