How to add a Trend pop up to a mimic
  • Remote Operations
  • How to add a Trend pop up to a mimic
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
KylePaynter1
Ensign KylePaynter1
Ensign
Posted: ‎2020-03-04 05:42 AM . Last Modified: ‎2023-05-03 12:16 AM
3617
Hi guys I would like to verify how to add a popup to show the trend for a point.
Example I have a grey box next to a text of a point/ tag and I would like to select or click that box and get the
  • Mimics
  • SCADA
  • Trends
geoffpatton
Captain geoffpatton
Captain
Posted: ‎2020-03-04 06:31 AM
In response to geoffpatton
3596
If you want to just display the default quick trend you could set the button to Object Menu and only select trend, however, that will open a menu first to select from the trend options for the point, which are Display Current Trend and Display Historic Trend.
So the first option I gave it better if you want a one click display. you can also edit the way the trend graph is displayed in the first option to display how you want it to show every time it is opened.
On a displayed Quick trend you can right-click on areas and change some options. Like at the bottom you can change the columns that are displayed, but it does not stick and you have to do that every time.
Replies 4
geoffpatton
Captain geoffpatton
Captain
Posted: ‎2020-03-04 06:18 AM
3599
Add a new trend object to the database and configure it.
Then on your button pick action select hyperlink link to your trend object change the mode from Navigate Open as an inset.
geoffpatton
Captain geoffpatton
Captain
3597
KylePaynter1
Ensign KylePaynter1
Ensign
Posted: ‎2020-03-09 05:53 AM
Thanks much I will take a shot at it
KylePaynter1
Ensign KylePaynter1
Ensign
Posted: ‎2020-03-11 10:55 AM
It worked like a charm thanks a million
