Unable to read all points in CBDPoint
  • Remote Operations
  • Unable to read all points in CBDPoint
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
DavidSkilbeck
Lt. Commander DavidSkilbeck
Lt. Commander
Posted: ‎2020-03-09 03:41 AM . Last Modified: ‎2023-05-03 12:16 AM
2081
I am using the below code that reads from the CBDPoint table in GeoSCADA.
retobj = MySoap.ExecuteQuery("SELECT FullName FROM CDBPOINT", obj, out limit);
It works to a point. However it only reads two points.
There are more than 30 points in CDBPoint table.
If I copy one of the two points and paste it in, with a new name of course.
It will then read three.
If I create an internal tag from scratch it will not pick up on it.
I have not been able to find information on this so far.
Will the code only capture certain types of points for some reason?
  • SCADA
AndrewScott
Admiral AndrewScott
Admiral
Posted: ‎2020-03-09 04:17 AM
1
2077
This sounds like it might be an access control issue.
Does the user account used by you're program have read access to all of the points?
If it only has access to some of the points but not others then that would explain this behaviour.
Andrew Scott, R&D Principal Technologist, AVEVA
AndrewScott
Admiral AndrewScott
Admiral
1
2078
DavidSkilbeck
Lt. Commander
Posted: ‎2020-03-09 02:49 PM
In response to AndrewScott
thanks Andrew.
