Hide or Remove the form close button "X"
Select a Country
  • Remote Operations
  • Hide or Remove the form close button "X"
sbeadle
sbeadle Champion
335
AndrewScott
AndrewScott
125
BevanWeiss
BevanWeiss
103
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
Ali80
Ali80 Explorer
Explorer
Posted: ‎2020-02-05 10:49 PM . Last Modified: ‎2023-05-03 12:17 AM
5993
Hi. Perhaps has somebody a good idea how I can remove or hide the popup close button. This popup was created with the VBscrpt language with the commands "Form.Init()" ... "Form.Show()" I can't find in the help or in the web a solution how I can remove "X". It exists also not form property for hide or an event which occur when I click on "X"
  • Scripting
  • ViewX
BevanWeiss
BevanWeiss
Champion
Posted: ‎2020-02-06 01:07 AM
In response to Ali80
1
5970
Here's some code... run it
Form.Init("Test Form")
Form.AddStaticText 10, 10, "Here's a form"
Form.Show()
MsgBox "We definitely returned afterwards"
Now if you click the 'X' and the MsgBox appears then you are wrong.
That means that after pressing the 'X' the control flow does indeed return to your (my) code.
Problem solved.
Replies 6
BevanWeiss
BevanWeiss
Champion
Posted: ‎2020-02-05 10:54 PM
5982
Unfortunately I don't think this is possible.
This is a VBscript form, so is outside the control of ViewX/ClearSCADA.
There's not really a way that I can think of to hack something similar either.  You could always handle the form closing using the 'X' (since the .Show() result will be empty) and re-display the form again.
Ali80
Ali80 Explorer
Explorer
Posted: ‎2020-02-05 11:11 PM
In response to BevanWeiss
5980
Thanks for the quick answer!! The problem is when the form opens then there is a variable in the database which is set to 1. If I push the "Cancel" button then the VBscript set this variable to 0. But if I push "X" then there is no chance to modify the variable. It's very pitty.
BevanWeiss
BevanWeiss
Champion
Posted: ‎2020-02-05 11:17 PM
5977
When the 'X' is pressed, control is still returned to your VBscript.
So you could have your VBscript detect this condition and do the most appropriate thing.
If that's to set your variable to 0, then you could do that, or you could redisplay the form if you really need to try to get them to enter correct values (although this obviously isn't bullet proof, if the user closes ViewX you don't get any valid entry).
Ali80
Ali80 Explorer
Explorer
Posted: ‎2020-02-05 11:48 PM
5973
Hey Bevan,
to your last answer:
That's not so. Unfortunately when the "X" was pressed the VBscript execution stopps. There is no part in the script which is after "X" continued.
BevanWeiss
BevanWeiss
Champion
1
5971
Form.Show()
Problem solved.
Ali80
Ali80 Explorer
Explorer
Posted: ‎2020-02-06 05:42 AM
Hi Bevan,
thank you very much. I'm so happy that it works. My problem was that I have realy long vb scripts and up to day I didn't know that the script continue after form.show(). Also my colleagues doesn't know this. I'll inform them.
Thanks a lot!!!!!!
Best regards
Alois
