Getting Template Name or id from an Instance
  • Remote Operations
  • Getting Template Name or id from an Instance
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
tkswathik
Lieutenant JG tkswathik
Lieutenant JG
Posted: ‎2021-11-23 05:21 PM . Last Modified: ‎2023-05-03 12:00 AM
2139
Is it possible to get the corresponding template name or Id of an Instance through the Automation Interface? My goal is to be able to find out if a property is overridden in the template
My code snippet is
InstanceFullName = "ParentGroup.InstanceName"
Set obj = server.FindObject(InstanceFullName)
TemplateId = obj.TemplateId
InstanceId = obj.InstanceId
I see that TemplateId is always 0 but InstanceId gives me the Id of ParentGroup if ParentGroup is another Template Instance otherwise I get 0
Eventually I would like to execute the following method on a few property names
tobj.PropertyOverride(TemplateId, PropertyName) (tobj -> Item inside the template)
  • SCADA
  • Scripting
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
Replies 4
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2021-11-24 08:15 PM
3
2121
I think you'll probably want the 'ParentTemplateId' property.
Which is described as "Reference to the template containing the object, if any."
So if the object has a ParentTemplateId that is not -1 then it is from a template, and you could reference the ID to obtain that template.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
tkswathik
Lieutenant JG
Posted: ‎2021-11-29 09:49 AM
In response to BevanWeiss
2099
@BevanWeiss
I don't see a ParentTemplateId method for SCXV6Object. I think you might have referred to the Property ParentTemplateId. I get -1  for both for an independent object( not part of any template) or a template object. I think the reason could be because the object I am checking is inside a template instance. So when I try ParentInstanceId, I get the "Id" of the Parent Group Instance.
I think I can work with this idea:
Lets say obj is the object for which I have to check if a property is overridden
1. Get the Parent Instance Id : obj.Property("ParentInstanceId")
2. Find the corresponding Group Object:
3. Get the Template Id property from the Group Object ( we cant use this on obj because it will fail)
4. Find the Corresponding Template Object ( tObj )
5. Use the Find method under SCXV6Object to see if the Instance Name ( obj.Name ) exists in the template
6. If it exists then use the  PropertyOverride  method:  tObj.PropertyOverride( tpObj.Id, propertyName). This would return either TRUE or FALSE
 tpObj would be Nothing if obj.Name doesn't exist in the Template
Thanks!!
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2021-11-29 01:41 PM
In response to tkswathik
2094
Huh?  Wasn't my first sentence exactly this.. "I think you'll probably want the 'ParentTemplateId' property."
But yes, my mistake, the ParentTemplateId property applies to tell if a point is within a Template (and which Template), not whether it is within an Instance of a Template.  So it is the 'ParentInstanceId' property you would want.
ParentInstanceId should return you the ID of the CTemplateInstance in which your object is located (if it is associated with an instance).
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
tkswathik
Lieutenant JG
Posted: ‎2021-11-29 01:51 PM
Ah !! I overlooked it, my bad.
Thanks for your suggestion
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
