Posted: 2022-08-15 04:20 AM . Last Modified: 2023-05-02 11:53 PM
Get Telemetry Data without "null"
I created an SQL Query in Geo SCADA Expert 2021 as in the below.
When I exported the Telemetry Signal List after creating the query, I saw "null" data. This "null" data should not be displayed
I did some filtering in this screen in the below but I couldn't be successful. Which filter i must choose?
ViewX
Posted: 2022-08-15 04:52 AM
To filter the resultset of an SQL query based on a column not being NULL use the <column> IS NOT NULL syntax:
https://www.w3schools.com/sql/sql_null_values.asp
The current value of a point is NULL when it has never been updated and the OPC quality will be 'waiting for initial data'.
Andrew Scott, R&D Principal Technologist, AVEVA
Posted: 2022-08-15 10:13 PM . Last Modified: 2022-08-16 11:31 PM
"select x,y, z
from tableName
where x is not null"
To filter a results without null values
OR another filter
where x >= 0
Posted: 2022-08-16 02:00 AM
The correct syntax to exclude NULL values is:
SELECT X, Y, Z FROM TABLE WHERE X IS NOT NULL
The following syntax will not work as the SQL standard specifies that the comparison operators (=, <>, >= etc.) cannot be used to test for NULL (see https://www.w3schools.com/sql/sql_null_values.asp😞
SELECT X, Y, Z FROM TABLE WHERE X <> NULL
Posted: 2022-08-19 07:26 AM
Thanks for help. It worked.
Posted: 2023-12-13 05:03 AM
To refine the resultset of an SQL query by excluding rows where a specific column is NULL, employ the syntax <column> IS NOT NULL. For detailed information, refer to the following link:
https://www.w3schools.com/sql/sql_null_values.asp.
https://iqratechnology.com/academy/sql-training/sql-null/
In the context of point values, a NULL signifies that the point has not been updated, and the associated OPC quality is designated as 'waiting for initial data.
