Posted: 2023-12-07 10:40 PM
I really need the ability to get data from Embedded List. But there is no such option in the menu. Ctrl+С works only in system lists and does not work in Embedded List.
Please add 'Copy to clipboard' and 'Copy record to clipboard' option in the embedded list menu.
And in all menu lists.
Posted: 2023-12-08 07:51 AM
There is and Ideas section where we can propose changes. Near the top of the main Forum screen there are options to select Forum, Ideas, and Blog. I don't know if this has already been requested in there but I am pretty sure over the years quite a few people have requested this.
I have two workarounds I have used depending on the customer's need. You can Print from an Embedded list so Print as a PDF has worked and most PDF printers create files that allow the text to be copied.
The other is to make a User Query in the database, enter the same Query in it as the Embedded Query, and add a button to the mimic that displays the query in a system list, then copy works. The button that displays the User Query is set to Object Menu, linked to the object, and only the Queries option is selected. The only draw back I've noticed for this option if the user filtered or changed the time range on the embedded query they have to repeat it.
