GeoSCADA 6.80.7641.1 License shows DNP3 enabled, Server Status shows DNP3 status = no license
Showing results forย
Did you mean:ย
  • Remote Operations
  • GeoSCADA 6.80.7641.1 License shows DNP3 enabled, Server Status shows DNP3 status = no license
sbeadle
Kirk sbeadle Kirk
318
AndrewScott
Admiral AndrewScott
109
BevanWeiss
Spock BevanWeiss
96
AdamWoodlandToo
Lt. Commander AdamWoodlandToo
39
EcoStruxureโ„ข Geo SCADA Expert
Critcho
Crewman Critcho
Crewman
Posted: โ€Ž2021-02-24 09:27 AM . Last Modified: โ€Ž2023-05-03 12:05 AM
3778
Hi guys,
I've set up a test server, using a licence dongle. I tried to set up a DNP3 TCP direct channel, but it was always failed; Quality = Device Failure. When I tried to enable logging on the comms channel per https://tprojects.schneider-electric.com/GeoSCADAHelp/Geo%20SCADA%202020/Default.htm#ServerAdministr..., I noticed that it shows DNP3 as "No License". But my License Details shows DNP3 is enabled. What am I missing here?
2021-02-23 GeoSCADA Licence shows DNP enabled but Serve Status shows DNP not licensed - Censored.png
Thanks for your help,
Scott
  • DNP3
  • SCADA
  • WITS
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
AdamWoodland
AdamWoodland Schneider Alumni (Retired)
Posted: โ€Ž2021-02-24 12:38 PM
7
3772
That's usually caused by having unlicensed extensions to the DNP3 driver, if you have them installed and one isn't licensed it takes the whole driver out. Run the installer and check, given you have the core DNP3 and DNP3 WITS you probably have the ENET extension installed but not licensed.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Replies 8
AdamWoodland
7
3773
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
BevanWeiss
Spock BevanWeiss
Spock
Posted: โ€Ž2021-02-24 02:48 PM
In response to AdamWoodland
3767
As Adam said, WITS, ENET and x70 are potential extensions which aren't the generic DNP3 licence (although ENET and x70 are out of the box licences... I'm think WITS may be an extra costed licence)
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
AdamWoodland
Posted: โ€Ž2021-02-24 03:07 PM
In response to BevanWeiss
3764
What's odd is the screenshot of the licence isn't showing the standard out of the box licence with all the standard drivers included. So wondering if this was something special someone was testing.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
BevanWeiss
Spock BevanWeiss
Spock
Posted: โ€Ž2021-02-24 06:54 PM
3751
Ohh right yeah... that dongle licence looks super dodgy.
Either it was generated really badly outside of Schneider, or it was very badly generated internally within Schneider.
In the first case, I'd suggest joining a witness protection program and not speaking of this again... in the second case I'd raise it with your Schneider support contact, and get the dongle code re-generated.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
geoffpatton
Captain geoffpatton
Captain
Posted: โ€Ž2021-02-25 06:21 AM
It could be some specially negotiated low cost minimum licensing.
At my previous company we did this with Citect. the licensing would only run as a single server, with Modbus and like 1500 points.
It was supposed to be a easier foot in the door and then get them to upgrade. It was kind of a flop. I only recall a few installations, and they did not grow. very small municipalities.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Critcho
Crewman Critcho
Crewman
Posted: โ€Ž2021-02-25 10:44 AM
Thanks @AdamWoodland, looks like that was the issue. I uninstalled DNP3.SCADAPack E (Kept DNP3.WITS), still didn't work. I then went through the installer again, and uninstalled anything that I absolutely didn't need; I'm guessing Schneider Electric SCADAPack x70.DNP3 Protocol was the problem. This must have been installed by default, I have absolutely no need for it, I wouldn't have picked it manually.
I know GeoSCADA is a massive system, and this problem is rare, but it could have been handled better, instead of leaving me guessing.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Critcho
Crewman Critcho
Crewman
3711
@BevanWeiss there is nothing "dodgy" about the licence, and I'm surprised to see remarks like that on what I thought was a professional forum. It is a cut-down licence specifically generated for suppliers to test their equipment against GeoSCADA using the WITS protocol.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
BevanWeiss
Spock BevanWeiss
Spock
Posted: โ€Ž2021-02-25 02:06 PM
In response to Critcho
@Critcho
dodgy
adjective
 UK informal
  - likely to fail or cause problems
Given you were posting to a forum about how the licence is causing you problems, tell me again how this was not dodgy?
I would have expected that with such a cut down licence, which is most definitely not 'normal', there would have been some specific use-instructions associated with it.  So when installing a ClearSCADA / Geo SCADA Expert installation you would have had details on exactly which boxes in the installer to tick for this particular licence.
All that aside, you get what you pay for.. both in licences, and in forums ๐Ÿ˜‰
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
ย
WHATโ€™S NEXT?
Terms & Conditions Privacy Notice Change your Cookie Settings ยฉ 2025 Schneider Electric
