Geo SCADA: Alarm Acknowledge Using Pick Action VBScript Function
Send InviteCancel
and then when using the method "objAlarm.Interface.Accept" it would accept all active alarms on that object. Is there any way to select a row in an alarm list and get a reference to the Alarm Instance and not the object or "Alarm Source".
The objAlarm item there is really the Alarm Object (CAlarmObject)
And hence the Accept will 'Acknowledges all alarms associated with the object'
So somewhat painfully, you'd ideally want to access the CAlarm itself instead of the Alarm Object.
Lead Control Systems Engineer for Alliance Automation (VIC). All opinions are my own and do not represent the opinions or policies of my employer, or of my cat..
