Executing Logic Block From another Logic Block
  • Remote Operations
  • Executing Logic Block From another Logic Block
sbeadle
Kirk sbeadle Kirk
321
AndrewScott
Admiral AndrewScott
116
BevanWeiss
Spock BevanWeiss
99
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
MichaelAur
Ensign MichaelAur
Ensign
Posted: ‎2024-03-26 01:46 AM
1350
I apologise is this is a simple question. But I cant seem to find a programming manual/database for the functions and and keywords available in logic modules specifically structured text.
For my we have some logic blocks that we only want executed on specific (and slightly complex) conditions.
Is it possible to call this logic block from another logic block eg something like below. I know I could nest this into the existing code. But this would require me to manual edit hundreds of already cluttered function blocks. Where as with this I could do some simple copy pasting and set the execution interval to 0s.
PROGRAM NewStructuredTextProgram
	VAR
		wOldValue: REAL;
	END_VAR
	VAR
		wCurValue AT %I(...Mapping.VARS.Control.xxx) : WORD;
		xLostComms AT %I(.LostComms): BOOL;
	END_VAR
	METHOD
		Exec AT %M(.MySecondayLogic.Execute): BOOL;
	END_METHOD
(*If value changed and not lost comms call other logic module*)
	IF(Not(xLostComms) AND  (wOldValue <> wCurValue )THEN
                wOldValue:= wCurValue;
        END_IF
END_PROGRAM
For reference Geo SCADA Expert 2021 (Build 84.8650)
  • Logic
  • ViewX
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
geoffpatton
Captain geoffpatton
Captain
Posted: ‎2024-03-26 07:08 AM
1
1343
You can declare a METHOD that references a logic program.Execute and then execute it.
You can also pass parameters if you declare them in the logic program you are executing.
This one just checks comm status to decide if it should execute the next logic.
METHOD
Exec_Next_Logic RL AT %M(.My Next ST.Execute);
END_METHOD
VAR
DNP_OSState AT %I(....Comms.Outstation.DNP Outstation.State) : REAL;
END_VAR
IF DNP_OSState <> 0 AND DNP_OSState <> 1 AND DNP_OSState <> 2 AND DNP_OSState <> 3 AND DNP_OSState <> 4 THEN
Exec_Next_Logic();
END_IF;
END_PROGRAM
This one passes a path to the next logic which has
VAR_INPUT
ParentFolderInput : STRING;
END_VAR
defined in it.
METHOD
MyExec AT %M(.My Logic ST.Execute):STRING;
END_METHOD
VAR
ParentFolder AT %M(..FullName) : STRING;
END_VAR
VAR_INPUT
END_VAR
ParentFolderInput := CONCAT(ParentFolder, '.DI.%');
MyExec(ParentFolderInput);
END_PROGRAM
geoffpatton
Captain geoffpatton
Captain
1
1344
METHOD
END_METHOD
VAR
END_VAR
Exec_Next_Logic();
END_IF;
END_PROGRAM
VAR_INPUT
END_VAR
defined in it.
METHOD
END_METHOD
VAR
END_VAR
VAR_INPUT
END_VAR
END_PROGRAM
geoffpatton
Captain geoffpatton
Captain
Posted: ‎2024-03-26 12:24 PM
The Help has references to functions and Function blocks. FBD and ST are covered in the same sections. Sometimes it is easier to create your basic logic in a FBD, then "Compile it with Diagnostics", highlight and copy the generated program, that is displayed at the bottom of the FBD window, to a ST program.
Built-in Functions, Function Blocks, and Conversions
https://tprojects.schneider-electric.com/GeoSCADAHelp/Geo%20SCADA%202022/Default.htm#LogicGuide/Buil...
MichaelAur
Ensign MichaelAur
Ensign
Posted: ‎2024-03-27 12:19 AM
In response to geoffpatton
Thanks so much. Nice and simple
