Date Time Picker
Select a Country
  • Remote Operations
  • Date Time Picker
sbeadle
sbeadle Champion
335
AndrewScott
AndrewScott
125
BevanWeiss
BevanWeiss
104
  • Remote Operations Forum
EcoStruxure™ Geo SCADA Expert
DavidSkilbeck
DavidSkilbeck
Contributor
Posted: ‎2020-11-11 01:51 AM . Last Modified: ‎2023-05-03 12:07 AM
4000
Date Time Picker
do we have access to a date / time picker from the mimic or via vbscript?
Does a time point have to be used.
I need a way for the operator to select a date (no time) and then I need to put that date into a string with no "/" in it.
Into this format 20200830 for example.
  • SCADA
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
tfranklin
tfranklin
Leader
Posted: ‎2020-11-11 01:30 PM . Last Modified: ‎2020-11-11 01:36 PM
3971
There's a form function for Form.AddDateTime that'll do what you want.  You can pull the value from a user input then format it in script however you want.
i think the syntax would be something like
set startDT = form.adddatetime(1,1)
then once the user hits OK you can use startDT.value as the variable you format
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Replies 4
geoffpatton
geoffpatton
Leader
Posted: ‎2020-11-11 06:18 AM
Only thing I know is you can use a Variable Time object and give the user access to the set value method. It has a time also but they can just know to ignore that. You can then take that value and edit the string to just be the numbers for month day and year.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
tfranklin
tfranklin
Leader
3972
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
DavidSkilbeck
DavidSkilbeck
Contributor
Posted: ‎2020-11-11 06:06 PM . Last Modified: ‎2020-11-11 08:39 PM
In response to tfranklin
3954
It does work.
However, I cant find anything that changes the format neatly.
I can do it via code below. But its crude.
StartDate.Value = CSTR(DateAdd("d",-14,now))
StartDate.Value = Left(StartDate.Value, 10)
StartDateValue = (Replace(StartDate.Value,"/",""))
year = Right(StartDateValue, 4)
MsgBox year
month = Mid(StartDateValue,3,2)
MsgBox month
day = Left(StartDate, 2)
MsgBox day
StartDateValue = year + month + day
MsgBox StartDateValue
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
BevanWeiss
BevanWeiss
Champion
Posted: ‎2020-11-19 04:40 AM
In response to DavidSkilbeck
Once you have the DateTime value, you should be able to use VBscript stuff to format it a little
https://www.w3schools.com/asp/func_formatdatetime.asp
I'm pretty sure I've used this before...
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
